2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-21T09:00:03+00:00
    You're welcome. It might be a different combination on the SP3. I think the aim is to get the device charging before it goes through the OS startup so bypassing any Windows drivers, firmware, etc.
    2016-07-21T08:51:59+00:00
    @DatabaseJase - thanks for the quick reply.  At this point, I can't get the SP3 to hard reset with this Method (2 button reset), but will give it a shot again.
    2016-07-21T08:37:09+00:00
    I've contacted BBC news (http://www.bbc.co.uk/news/10725415) about this so hopefully we can get it covered to raise awareness and embarrass Microsoft into some action.
    2016-07-21T07:51:34+00:00
    At least the #BatteryGate issue is getting great coverage from well respected Microsoft bloggers although the part about someone raising this internally is very worrying...
    http://winsupersite.com/hardware/surface-pro-3-battery-gate-piecing-it-together
    @DarrellStroope - I think this is a result of the battery being completely depleted.  There was a firmware issue with SP2 and someone suggested holding down the power button and volume up (I think it was) until the Surface logo appears and then leave it charging (ideally using the direct charging cable not a docking station).  I think I posted a link to that SP2 issue further back in this topic.
    EDIT: Thought so but here is it again for ease of access: http://news.softpedia.com/news/How-to-Fix-Surface-Pro-2-Plugged-In-Not-Charging-Error-412945.shtml
