2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-21T18:47:28+00:00
    Have your tried the method posted on this forum to recover the battery?
    2016-07-21T18:38:57+00:00
    This is my battery report:
    2016-04-10 - 2016-04-17 42,275 mWh 42,157 mWh
    2016-04-17 - 2016-04-24 37,419 mWh 42,157 mWh
    2016-04-24 - 2016-05-01 35,376 mWh 42,157 mWh
    2016-05-01 - 2016-05-08 29,328 mWh 42,157 mWh
    2016-05-08 - 2016-05-15 27,319 mWh 42,157 mWh
    2016-05-15 - 2016-05-23 26,181 mWh 42,157 mWh
    2016-05-23 - 2016-05-30 18,605 mWh 42,157 mWh
    2016-05-30 - 2016-06-06 15,517 mWh 42,157 mWh
    2016-06-06 - 2016-06-13 14,490 mWh 42,157 mWh
    2016-06-13 - 2016-06-20 12,676 mWh 42,157 mWh
    2016-06-20 - 2016-06-27 9,506 mWh 42,157 mWh
    2016-06-27 - 2016-07-04 6,598 mWh 42,157 mWh
    2016-07-04 - 2016-07-11 5,103 mWh 42,157 mWh
    2016-07-12 2,789 mWh 42,157 mWh
    2016-07-13 2,789 mWh 42,157 mWh
    2016-07-14 2,789 mWh 42,157 mWh
    2016-07-15 2,431 mWh 42,157 mWh
    2016-07-16 2,067 mWh 42,157 mWh
    2016-07-17 2,067 mWh 42,157 mWh
    2016-07-18 2,067 mWh 42,157 mWh
    2016-07-21T17:16:22+00:00
    I posted my battery results earlier.  When I go to try and contact Microsoft about the problem they say it will cost $99 for them to talk about my SP3.
    Has anyone found a way to report the problem without this charge?
    2016-07-21T10:49:32+00:00
    Has anyone had an issue where the SP3 will not power on at all?  I have two, wife's and mine.  Mine is degrading... albeit not as fast as some of the reports in this post.  But about 1 week ago, My wife's which had been seeing significant degradation will no longer power on.  I've tried every reset possible 1 button, 2 button, and the only indication during the reset is the light on the Charger will flash occassionaly.  Usually it comes back on... sometimes it doesn't.  At this point it's a brick!
    Hi Darrell,
    Yes this is what happened to mine, and I think will happen to everyone on this thread, they stop rebooting / powering on and become a brick.
    So even getting the battery repaired only buys another year or so, this is a design flaw.
