2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-21T07:40:30+00:00
    Has anyone had an issue where the SP3 will not power on at all?  I have two, wife's and mine.  Mine is degrading... albeit not as fast as some of the reports in this post.  But about 1 week ago, My wife's which had been seeing significant degradation will no longer power on.  I've tried every reset possible 1 button, 2 button, and the only indication during the reset is the light on the Charger will flash occassionaly.  Usually it comes back on... sometimes it doesn't.  At this point it's a brick!
    2016-07-21T01:07:03+00:00
    I've been having this issue for a while.  What's sad is that based on my powercfg report, the battery degradation began during my warranty period, which expired 12/15.  As of Jan, i had already started to lose significant capacity.  Talked with tech support, got e-mail with instructions, followed them all. No dice.  Read about the $200 AMA quote to fix the battery, only to discover it was just untrue.  $500 for a fix is nuts - or rather, I would be nuts to sink another half-grand into this mess.  Have paid $1500 for device that turns into a paperweight within 1 minute of unplugging it.
    Eagerly anticipating either a resolution from MS or to join the class action law suit that I imagine is right around the corner.
    244 cycle count, 144mWh capacity at full charge.  Awesome.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=c7b1faf8-cea0-4886-a2be-4538e9d3d5c9)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=7954e854-ebb9-48c5-81a0-fb1e2e24c7e0)
    2016-07-21T01:06:20+00:00
    I have also observed the same degradation problem with my SP3 with 114 cycles and battery SIMPLO, but I'd like to share my experience in case it could help to somebody. I have recovered the battery at 100% capacity, after the apparent degradation.
    In my experience I have noticed the problem of degradation quite early when arrived to 31mWh of full charge capacity, and it was degrading consistently all days 2% to 3%, It made me aware and then confirm in forums that I was not the only one with this problem and even with cases more advanced of this problem. I used to use the SP3 almost all the time connected to the dock, I used in battery eventually when I needed mobility and at least a discharge once a month as recommended in the manual.
    At this point with a maximum charge capacity at 31mWh I took a few actions: a reinstallation of the battery driver, and the most important I change the way of use of the equipment (always leave it disconnected of the electrical power supply or unplugged from the dock after turning it off while i was not using it, for several hours every day) :
    First of all, I went back to the previous version of the driver of the battery and reboot, then update it again with the last driver of the battery and restart.
    Afterwards I started to always leave it disconnected from the electrical power supply after turning it off or Hibernate, for many hours, basically throughout the night and part of the day.
    Then, each day with patience used it only on battery up to 50% or 60% and then connecting it to charge it. While I was doing this I realized that is was taking more time for  loading when arrived to the 99% and when it got to the 100%, the capacity of load was of 2 to 3% more than the charge capacity of the previous day, and I did it during a week, until now  that it reached the 100% of the capacity again.
    Attached my battery report where you can see first the degradation, and then the recovery of capacity.
    In order to verify, I've tried to use it on battery up to 15% with use of normal light web browsing tasks, eventually some videos, etc. lasting now more than 8 hrs. then charge to the 100% of the normal capacity again.
    I hope my experience can help, try it  (I do not know if it can help with a very advanced degradation) and comment and sharing to verify it.
    Also I would like to confirm if leave connected to power supply when not is in use is what is affecting the degradation of the battery?
    So far, now I have panic of maintain it connected after the charge, at least until clarification of what is the cause of this problem.
    I have bought my SP3 in USA and my warranty expires in OCT-2016, but I live in Argentina, so i cannot take it for an Exchange as a first alternative.
    BEFORE
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=c6cf3122-c958-455e-a448-ea196cad5214)
    AFTER
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=8613fe95-06b7-4724-b70a-03dbeb09310c)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=d15dfac6-ae5a-4b18-a8ee-c27d34c0d90b)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=e5c60663-e5ad-49d3-804c-78ef675a7a83)
    2016-07-20T23:13:02+00:00
    I just want to add my name to this list as well as having problems with the SP3 battery life. I've always attributed this as a side effect of being on the fast ring for preview builds, but now I am a bit more concerned.
    The biggest concern is how much full charge capacity it is losing per day:
    July 16 21,379 mWh
    July 17 21,280 mWh
    July 18 20,351 mWh
    July 19 19,122 mWh
    July 20 18,658 mWh.
    At this rate it will be dead by early-mid August.
