2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-20T20:16:26+00:00
    I will add my surface pro 3 to the ring as well
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 1,588 mWh
    CYCLE COUNT 217
    Battery capacity history
    Charge capacity history of the system's batteries
    2016-05-01 - 2016-05-08 7,735 mWh 42,157 mWh
    2016-05-08 - 2016-05-15 5,634 mWh 42,157 mWh
    2016-05-15 - 2016-05-22 2,773 mWh 42,157 mWh
    2016-05-22 - 2016-05-29 1,764 mWh 42,157 mWh
    2016-05-29 - 2016-06-05 1,669 mWh 42,157 mWh
    2016-06-05 - 2016-06-12 1,672 mWh 42,157 mWh
    2016-06-12 - 2016-06-19 1,672 mWh 42,157 mWh
    2016-06-19 - 2016-06-26 1,672 mWh 42,157 mWh
    2016-06-26 - 2016-07-03 1,672 mWh 42,157 mWh
    2016-07-03 - 2016-07-10 1,672 mWh 42,157 mWh
    2016-07-11 1,672 mWh 42,157 mWh
    2016-07-12 1,672 mWh 42,157 mWh
    2016-07-13 1,672 mWh 42,157 mWh
    2016-07-14 1,672 mWh 42,157 mWh
    2016-07-15 1,672 mWh 42,157 mWh
    2016-07-16 1,672 mWh 42,157 mWh
    2016-07-17 1,672 mWh 42,157 mWh
    2016-07-18 1,672 mWh 42,157 mWh
    2016-07-19 1,672 mWh 42,157 mWh
    Glad to know I wasn't the only one with a problem. Lets keep this thread going.
    2016-07-20T19:14:18+00:00
    I posted in another thread a while back about this and since then mine has even gotten worse.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=4d1ef589-e6cc-4c48-b85d-880cfe832e3b)
    2016-07-20T17:11:17+00:00
    I have this issue as well.  I took it to the Microsoft store and the guy told me that it was my fault because I usually leave it plugged in to the port, and that a new battery would be $450.  I have had the Surface Pro 3 for 18 months and my cycle count is only 57!!!!  I am really surprised that Microsoft knows about this issue and hasn't offered a reasonable solution.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=d3b7ab44-3c59-4d5f-9bec-792687babf7c)
    2016-07-20T16:55:23+00:00
    I recently contacted Microsoft support with this issue as well. After extensive troubleshooting I was told that a $500 replacement was my only option I typically get 30 minutes to one hour of battery life.
    Battery Report
    COMPUTER NAME DARYLTABLET
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.1150 12/09/2015
    OS BUILD 10586.494.amd64fre.th2_release_sec.160630-1736
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-07-2012:42:54
    Installed batteries
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1167661572
    CHEMISTRY LION
    FULL CHARGE CAPACITY 10,792 mWh
    CYCLE COUNT 459
    2016-01-11 - 2016-01-25 40,260 mWh 42,157 mWh
    2016-01-25 - 2016-02-08 40,468 mWh 42,157 mWh
    2016-02-08 - 2016-02-14 40,491 mWh 42,157 mWh
    2016-02-14 - 2016-02-21 40,482 mWh 42,157 mWh
    2016-02-21 - 2016-02-29 40,546 mWh 42,157 mWh
    2016-02-29 - 2016-03-06 42,422 mWh 42,157 mWh
    2016-03-06 - 2016-03-13 41,210 mWh 42,157 mWh
    2016-03-13 - 2016-03-21 36,499 mWh 42,157 mWh
    2016-03-21 - 2016-03-27 33,948 mWh 42,157 mWh
    2016-03-27 - 2016-04-04 32,163 mWh 42,157 mWh
    2016-04-04 - 2016-04-11 31,199 mWh 42,157 mWh
    2016-04-11 - 2016-04-25 22,962 mWh 42,157 mWh
    2016-04-25 - 2016-05-02 17,691 mWh 42,157 mWh
    2016-05-02 - 2016-05-16 11,913 mWh 42,157 mWh
    2016-05-16 - 2016-05-23 10,420 mWh 42,157 mWh
    2016-05-23 - 2016-05-30 13,618 mWh 42,157 mWh
    2016-05-30 - 2016-06-06 15,493 mWh 42,157 mWh
    2016-06-06 - 2016-06-13 17,975 mWh 42,157 mWh
    2016-06-13 - 2016-06-20 22,584 mWh 42,157 mWh
    2016-06-20 - 2016-06-27 23,370 mWh 42,157 mWh
    2016-06-27 - 2016-07-04 20,495 mWh 42,157 mWh
    2016-07-04 - 2016-07-11 18,413 mWh 42,157 mWh
    2016-07-12 15,564 mWh 42,157 mWh
    2016-07-13 14,427 mWh 42,157 mWh
    2016-07-14 14,166 mWh 42,157 mWh
    2016-07-15 14,166 mWh 42,157 mWh
    2016-07-16 14,166 mWh 42,157 mWh
    2016-07-17 14,166 mWh 42,157 mWh
    2016-07-18 14,166 mWh 42,157 mWh
    2016-07-19 12,481 mWh 42,157 mWh
    Battery life estimates
    Battery life estimates based on observed drains
    2016-01-11 - 2016-01-25 3:54:27 90:06:34<br><br>18 % / 16 h 4:05:30 94:21:19<br><br>17 % / 16 h
    2016-01-25 - 2016-02-08 3:16:12 119:36:08<br><br>13 % / 16 h 3:24:23 124:35:38<br><br>13 % / 16 h
    2016-02-08 - 2016-02-14 3:21:49 106:33:22<br><br>15 % / 16 h 3:30:07 110:56:25<br><br>14 % / 16 h
    2016-02-14 - 2016-02-21 3:48:20 65:04:39<br><br>25 % / 16 h 3:57:47 67:46:13<br><br>24 % / 16 h
    2016-02-21 - 2016-02-29 3:58:49 66:21:09<br><br>24 % / 16 h 4:08:18 68:59:20<br><br>23 % / 16 h
    2016-02-29 - 2016-03-06 3:12:00 26:58:19<br><br>59 % / 16 h 3:10:48 26:48:12<br><br>60 % / 16 h
    2016-03-06 - 2016-03-13 - - - -
    2016-03-13 - 2016-03-21 4:27:03 105:21:12<br><br>15 % / 16 h 5:08:27 121:41:06<br><br>13 % / 16 h
    2016-03-21 - 2016-03-27 3:33:49 38:05:16<br><br>42 % / 16 h 4:25:31 47:17:52<br><br>34 % / 16 h
    2016-03-27 - 2016-04-04 3:43:42 24:48:55<br><br>64 % / 16 h 4:53:13 32:31:34<br><br>49 % / 16 h
    2016-04-04 - 2016-04-11 3:16:22 27:50:35<br><br>57 % / 16 h 4:25:20 37:37:21<br><br>43 % / 16 h
    2016-04-11 - 2016-04-25 2:12:54 64:27:17<br><br>25 % / 16 h 4:04:00 118:20:07<br><br>14 % / 16 h
    2016-04-25 - 2016-05-02 1:26:03 47:06:45<br><br>34 % / 16 h 3:25:04 112:16:02<br><br>14 % / 16 h
    2016-05-02 - 2016-05-16 0:52:34 11:09:41<br><br>143 % / 16 h 3:06:01 39:29:52<br><br>41 % / 16 h
    2016-05-16 - 2016-05-23 - - - -
    2016-05-23 - 2016-05-30 1:19:51 5:10:11<br><br>309 % / 16 h 4:07:12 16:00:16<br><br>100 % / 16 h
    2016-05-30 - 2016-06-06 1:42:58 81:51:36<br><br>20 % / 16 h 4:40:12 222:44:39<br><br>7 % / 16 h
    2016-06-06 - 2016-06-13 2:25:09 8:49:04<br><br>181 % / 16 h 5:40:26 20:40:50<br><br>77 % / 16 h
    2016-06-13 - 2016-06-20 1:56:10 15:14:50<br><br>105 % / 16 h 3:36:51 28:27:43<br><br>56 % / 16 h
    2016-06-20 - 2016-06-27 2:20:46 18:48:24<br><br>85 % / 16 h 4:13:56 33:55:31<br><br>47 % / 16 h
    2016-06-27 - 2016-07-04 2:18:47 56:50:48<br><br>28 % / 16 h 4:45:30 116:55:49<br><br>14 % / 16 h
    2016-07-04 - 2016-07-11 2:10:09 30:32:39<br><br>52 % / 16 h 4:58:00 69:55:55<br><br>23 % / 16 h
    2016-07-12 1:29:46 - 4:03:09 -
    2016-07-13 1:12:00 2:27:25<br><br>651 % / 16 h 3:30:25 7:10:48<br><br>223 % / 16 h
    2016-07-14 - - - -
    2016-07-15 - - - -
    2016-07-16 - - - -
    2016-07-17 - - - -
    2016-07-18 - - - -
    2016-07-19 1:03:18 10:25:35<br><br>153 % / 16 h 3:33:49 35:13:03<br><br>45 % / 16 h
    Current estimate of battery life based on all observed drains since OS install
    Since OS install 1:01:46 11:33:06<br><br>139 % / 16 h 4:01:18 45:07:31<br><br>35 % / 16 h
