2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-10-08T01:31:58+00:00
    I want in on that
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=3a1ee784-b1d4-48b6-b59e-6c3ceba68dd6)
    2016-10-07T16:07:37+00:00
    Since this is a SIMPLO battery, and you're trying to download and install the August firmware, I think your best bet is to visit a Microsoft store and get them to do it. They don't charge anything for in-person interaction. Pretty sure!
    2016-10-07T16:00:04+00:00
    Is anyone aware of a class action lawsuit I can sign on to for this?  I am ready to sue.
    My gripes are this is a known problem and well publicized but Microsoft is stonewalling us.
    They want to charge $99 just to talk to a support person and then 450 to get it fixed (local currency).  That's absurd.  They once claimed out of warranty batteries would be just 200 (local currency) to replace.
    I got my entire office in on surfaces and now I regret doing business with Microsoft at all.
    I would be very thankful for anyone who could point me at a class action lawsuit.
    2016-10-06T11:26:55+00:00
    It's totally same as mine!!
    MS should fix this issue asap!!!
