2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-10-10T13:18:35+00:00
    My SP3 just got out of warranty in August 2016... and I need to pay $99 to call support.
    2016-10-10T13:14:19+00:00
    Barb,
    My SP3 with SIMPLO battery does the same thing, it cannot stay online without the AC and the battery shows 99% charged but not charging at all. This is clearly a firmware issue affecting not just LGC.
    Ben
    I have a simplo & it was fixed with the last update.
    I very much doubt your issue is still fw related...
    Call support to do some rigorous testing that'll 100% rule-out hw.
    Though one thing I've noticed...
    Is that run time on battery while being used lightly, is way less than what they stated when SP3 1st came out.
    Also, run time "in use" on official documentation is notably lower now, but mine's still way short of even that.
    Battery looks to have worn to ~88% in ~20mth, not bad, but not great either.
    With the short run time, it seems like capacity should be much lower than that.
    2016-10-10T12:01:46+00:00
    Barb,
    Ben
    I reported the same issue, perhaps Barb should open a new thread for everyone with the "not charging" issue to get the attention needed for resolution...
    2016-10-10T11:51:36+00:00
    Split from this thread.
    Barb,
    Ben
