2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-10-06T08:45:04+00:00
    Has anybody found a way to install the firmware when your battery level is under 40%?
    I have tried everything and nothing seems to work! It's really frustrating :(
    Imposing a battery level barrier for the firmware fixing the same faulty battery is absurd.
    Isn't there anybody who has the same problem as me?
    I first updated my firmware using Windows Update and followed up the two restart instruction but it didn't work.
    Then I downloaded the firmware manually and installed it but it didn't work either.
    While booting, firmware update progress bar goes near 100% and then device restarts and when I log on I see that the firmware isn't installed.
    Now my battery status icon in task bar shows "No battery detected" but when I click on it shows my battery is fully charged.
    2016-10-01T14:53:44+00:00
    One person has found not a fix but a temporary workaround:
    http://www.surfaceforums.net/threads/ms-surface-pro-3-battery-driver-problem.21508/
    2016-09-30T11:34:46+00:00
    the Surface team said on Reddit originally that using the SP3 5 days a week for
    two years would result in about 80% capacity as I recall.
    2016-09-30T11:09:23+00:00
    Hi all,
    I've applied the battery fix on my SP3, however, my battery life still isn't great. I've done a full discharge and re-charge to calibrate the battery, however, my battery capacity isn't improving. I have a SIMPLO battery with a cycle count of 227. Any idea why my full charge capacity is still much lower than the design capacity? Surely, it should not have degraded that much.
    Battery capacity history
    Charge capacity history of the system's batteries
    2016-09-21 32,718 mWh 42,157 mWh
    2016-09-22 32,718 mWh 42,157 mWh
    2016-09-23 32,709 mWh 42,157 mWh
    2016-09-24 32,703 mWh 42,157 mWh
    2016-09-25 32,703 mWh 42,157 mWh
    2016-09-26 31,758 mWh 42,157 mWh
    2016-09-27 31,069 mWh 42,157 mWh
    2016-09-28 31,549 mWh 42,157 mWh
    2016-09-29 32,574 mWh 42,157 mWh
