2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-09-29T15:41:01+00:00
    Wade, what are you trying to tell us? I replied to "waritch" and you replied to
    my reply.
    2016-09-29T14:42:32+00:00
    Battery report
    COMPUTER NAME SURFACEPRO
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.1450 05/27/2016
    OS BUILD 14393.0.amd64fre.rs1_release.160715-1616
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-09-29 09:33:36
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1167006212
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 42,583 mWh
    CYCLE COUNT 237
    Recent usage
    Power states over the last 3 days
    2016-09-29 08:36:18 Active Battery 72 % 30,613 mWh
    08:38:25 Suspended 70 % 30,020 mWh
    08:39:31 Active Battery 70 % 29,731 mWh
    08:50:28 Connected standby Battery 64 % 27,086 mWh
    09:22:49 Active Battery 61 % 26,182 mWh
    09:30:51 Active AC 59 % 25,072 mWh
    09:32:01 Report generated AC 60 % 25,338 mWh
    Battery usage
    Battery drains over the last 3 days
    2016-09-29 08:36:18 Active 0:02:07 1 % 593 mWh
    08:39:31 Active 0:10:57 6 % 2,645 mWh
    08:50:28 Connected standby 0:32:20 2 % 904 mWh
    09:22:49 Active 0:08:01 3 % 1,110 mWh
    Usage history
    History of system usage on AC and battery
    Battery capacity history
    Charge capacity history of the system's batteries
    Battery life estimates
    Battery life estimates based on observed drains
    Current estimate of battery life based on all observed drains since OS install
    Since OS install - - - -
    2016-09-29T10:12:01+00:00
    a fix was made available for Simplo batteries only on 8/29 via a firmware
    update.
    please open an admin cmd prompt and run
    copy and paste the ENTIRE output into a reply
    2016-09-28T19:19:04+00:00
    Has the SP3 battery fix been made available yet?  If so then how do I get it?  I go from a full charge to zero in just over an hour and I use my SP3 for school (bought in the MS Education Store) so I'm really screwed without the fix!  Please advise!  Thanks.
