2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-19T21:07:40+00:00
    Looks like Microsoft are starting to take notice according to this report:
    http://mspoweruser.com/many-surface-pro-3-customers-are-reporting-sudden-degrade-of-battery-life/
    Seems odd that they say to contact support, isn't that what we have been doing here on these forums and others by telephone?  Would have been nice if support had made a connection between all these common calls and escalated it without people being charged unnecessarily.
    Please keep posting your reports here.  The more voices the better as far as I'm concerned.
  2. Deleted
    2016-07-19T20:35:20+00:00
    Having the same problem.
    2016-07-19T20:27:23+00:00
    Unfortunately my surface pro 3 have damned battery brand and face same issue of quick degrading:
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1161370116
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 39,710 mWh
    CYCLE COUNT 96
    PERIOD FULL CHARGE CAPACITY DESIGN CAPACITY
    2016-07-16 40,128 mWh 42,157 mWh
    2016-07-17 40,108 mWh 42,157 mWh
    2016-07-18 39,710 mWh 42,157 mWh
    Hope to be just software issue
