2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-19T22:24:32+00:00
    2016-07-19T22:02:07+00:00
    I have a Surface Pro 3.  Of course it is outside its warranty period.
    I'm having a weird issue with my battery.  It's a Simplo battery.   The battery dies at night.  In the morning it won't even turn on.  It does this every night.   I don't seem to be having the issue that others are having where it won't hold a charge.  It just won't hold a charge at night.   The battery has no issue making it through the day.   I don't usually plug it in at night, but I never have.  Come 7 or 8PM the computer almost never gets turned on.
    I'm assuming something is scheduled to start up at night, but I'm not sure what it could be.  I'm going to try hibernating the computer or turning it off tonight to see if that makes a difference.
    Any idea on what could be killing the battery so bad, but only at night?
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=c9e0b61a-9efb-417a-aa4d-8fa3b7260914)![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=7d3be131-646f-442a-9093-5f755c958c0b)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=5cd72934-2dc2-4d16-bef2-10175b4baf24)
    2016-07-19T21:58:30+00:00
    My SP3 was purchased in late Nov. 2014 and has just started losing battery capacity since the end of May. It has lost 77% battery capacity in the last month and a half  Yesterday it took only 40 min for it to go from a full charge to shutdown doing only very minimal tasks.
    COMPUTER NAME CAROL
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.1150 12/09/2015
    OS BUILD 10586.494.amd64fre.th2_release_sec.160630-1736
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-07-18 21:29:22
    Installed batteries
    Information about each currently installed battery
    BATTERY 1
    NAME        X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1161107972
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 3,640 mWh
    CYCLE COUNT 218
    Battery capacity history
    Charge capacity history of the system's batteries
    PERIOD     FULL CHARGE CAPACITY DESIGN CAPACITY
    2015-11-14 39,953 mWh 42,157 mWh
    2015-11-15 - 2015-11-22 39,588 mWh 42,157 mWh
    2015-11-22 - 2015-11-29 39,813 mWh 42,157 mWh
    2015-11-29 - 2015-12-06 39,713 mWh 42,157 mWh
    2015-12-06 - 2015-12-13 39,504 mWh 42,157 mWh
    2015-12-13 - 2015-12-20 39,626 mWh 42,157 mWh
    2015-12-20 - 2015-12-27 39,730 mWh 42,157 mWh
    2015-12-27 - 2016-01-03 40,047 mWh 42,157 mWh
    2016-01-03 - 2016-01-10 40,009 mWh 42,157 mWh
    2016-01-10 - 2016-01-17 40,234 mWh 42,157 mWh
    2016-01-17 - 2016-01-24 40,187 mWh 42,157 mWh
    2016-01-24 - 2016-01-31 40,149 mWh 42,157 mWh
    2016-01-31 - 2016-02-07 40,267 mWh 42,157 mWh
    2016-02-07 - 2016-02-14 40,209 mWh 42,157 mWh
    2016-02-14 - 2016-02-21 40,327 mWh 42,157 mWh
    2016-02-21 - 2016-02-28 40,586 mWh 42,157 mWh
    2016-02-28 - 2016-03-06 40,436 mWh 42,157 mWh
    2016-03-06 - 2016-03-13 40,613 mWh 42,157 mWh
    2016-03-13 - 2016-03-20 40,556 mWh 42,157 mWh
    2016-03-20        40,440 mWh 42,157 mWh
    2016-03-20 - 2016-03-27 40,440 mWh 42,157 mWh
    2016-03-27 - 2016-04-03 41,124 mWh 42,157 mWh
    2016-04-03 - 2016-04-10 42,583 mWh 42,157 mWh
    2016-04-10 - 2016-04-17 42,583 mWh 42,157 mWh
    2016-04-17 - 2016-04-24 42,583 mWh 42,157 mWh
    2016-04-24 - 2016-05-02 42,479 mWh 42,157 mWh
    2016-05-02 - 2016-05-08 40,822 mWh 42,157 mWh
    2016-05-08 - 2016-05-15 40,996 mWh 42,157 mWh
    2016-05-15 - 2016-05-22 39,862 mWh 42,157 mWh
    2016-05-22 - 2016-05-29 39,862 mWh 42,157 mWh
    2016-05-29 - 2016-06-05 35,602 mWh 42,157 mWh
    2016-06-05 - 2016-06-12 26,371 mWh 42,157 mWh
    2016-06-12 - 2016-06-19 22,985 mWh 42,157 mWh
    2016-06-19 - 2016-06-26 16,119 mWh 42,157 mWh
    2016-06-26 - 2016-07-03 13,312 mWh 42,157 mWh
    2016-07-03 - 2016-07-10 10,302 mWh 42,157 mWh
    2016-07-11        10,169 mWh 42,157 mWh
    2016-07-12        10,169 mWh 42,157 mWh
    2016-07-13        10,169 mWh 42,157 mWh
    2016-07-14        10,169 mWh 42,157 mWh
    2016-07-15        10,169 mWh 42,157 mWh
    2016-07-16        10,169 mWh 42,157 mWh
    2016-07-17         9,681 mWh 42,157 mWh
    2016-07-19T21:34:21+00:00
    Mine too!! Battery lasts 25 minutes then starts the shutdown process.  Microsoft needs to fix this!!!
