2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-19T20:18:31+00:00
    I am also having this problem with my Surface Pro 3 - very frustrating, and it's out of warranty but otherwise works fine! Please help.
    2016-07-19T19:13:16+00:00
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1161173508
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 144 mWh
    CYCLE COUNT 288
    2016-07-19T18:38:39+00:00
    Having the same issue on my SP3 while my wife's will no longer start up at all.
    Installed batteries
    Information about each currently installed battery
    NAME X904849
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1180048900
    CHEMISTRY LION
    FULL CHARGE CAPACITY 39,231 mWh
    CYCLE COUNT 255
    2016-07-19T17:16:37+00:00
    me too!!!!!!
    I bought my SP3 at 20150101,and will be out of warranty at 2017/03/08
    I found my full charge capacity degradation at May
    here is my battery report with also a SIMPLO manufactured
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=320d8e65-0548-4541-9cbb-bf9186883cb0)
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=71ffc935-cfd4-497f-821a-d83ef0c7c8fe)
