2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-19T15:09:11+00:00
    I've been reading about the issue in social media and saw some people mention about buying 3 years warranty.
    Unfortunately, it seems like the 3 years warranty is not being offered in all countries. At very least, my country's version of Surface warrantypage only say "Your Surface is covered by a 1 year warranty" without any mention about the extended warranty. It's not available for purchase in the local version of http://www.microsoftstore.com/ and from some searching, this option is only available for business customer in case of my country.
    So in my case, and I'm sure quite few others here, it's not our fault that we didn't buy 3 years warranty. Some of us don't even have that choice to begin with. :(
    2016-07-19T14:48:18+00:00
    could some one please advise me if i should ask for a replacement on my battery as i have only 5 days left on my warranty...please look at my battery report below and kindly advice me what to do. thanks
          Battery report
    COMPUTER NAME SOWMI
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.1150 12/09/2015
    OS BUILD 10586.420.amd64fre.th2_release_sec.160527-1834
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-07-19 15:29:03
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1160976900
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 41,154 mWh
    CYCLE COUNT 23
    Recent usage
    Power states over the last 3 days
    2016-07-17 20:59:20 Connected standby Battery 90 % 37,134 mWh
    20:59:20 Active Battery 90 % 37,134 mWh
    22:09:53 Connected standby Battery 65 % 26,874 mWh
    22:35:24 Active Battery 65 % 26,729 mWh
    22:43:28 Connected standby Battery 63 % 26,022 mWh
    22:43:31 Active Battery 63 % 26,015 mWh
    22:54:42 Connected standby Battery 61 % 24,913 mWh
    2016-07-18 02:54:54 Suspended 59 % 24,176 mWh
    2016-07-19 14:25:11 Active Battery 58 % 23,948 mWh
    14:28:43 Connected standby Battery 57 % 23,530 mWh
    14:46:26 Active Battery 57 % 23,438 mWh
    15:29:00 Report generated Battery 36 % 15,018 mWh
    Battery usage
    Battery drains over the last 3 days
    2016-07-17 20:59:20 Connected standby 0:00:00 - -
    20:59:20 Active 1:10:32 25 % 10,260 mWh
    22:09:53 Connected standby 0:25:30 - 145 mWh
    22:35:24 Active 0:08:04 2 % 707 mWh
    22:43:28 Connected standby 0:00:02 - 7 mWh
    22:43:31 Active 0:11:10 3 % 1,102 mWh
    22:54:42 Connected standby 4:00:11 2 % 737 mWh
    2016-07-19 14:25:11 Active 0:03:31 1 % 418 mWh
    14:28:43 Connected standby 0:17:42 - 92 mWh
    14:46:26 Active 0:42:33 20 % 8,420 mWh
    Usage history
    History of system usage on AC and battery
    2016-02-28 - 2016-03-03 0:06:49 - 2:41:31 0:45:18
    2016-03-03 - 2016-03-08 0:20:49 1:55:48 - -
    2016-03-08 - 2016-04-08 0:47:44 4:13:14 - -
    2016-04-08 - 2016-04-16 0:41:57 4:16:32 0:39:52 1:32:33
    2016-04-16 - 2016-04-21 2:13:44 8:00:05 - -
    2016-04-21 - 2016-04-30 0:26:10 10:24:04 0:45:11 1:08:30
    2016-04-30 - 2016-05-04 0:56:21 8:40:37 - -
    2016-05-04 - 2016-05-18 4:12:03 29:45:22 1:14:07 1:25:16
    2016-05-18 - 2016-05-25 - - 167:37:37 -
    2016-05-25 - 2016-06-01 - - 167:59:59 -
    2016-06-01 - 2016-06-08 - - 167:59:59 -
    2016-06-08 - 2016-06-15 - - 167:59:59 -
    2016-06-15 - 2016-06-22 - - 167:59:59 -
    2016-06-22 - 2016-06-29 - - 167:59:59 -
    2016-06-29 - 2016-07-06 - - 167:59:59 -
    2016-07-07 1:33:11 0:42:19 20:36:11 1:06:21
    2016-07-08 4:13:56 0:57:35 0:00:10 4:34:24
    2016-07-09 - - - -
    2016-07-10 - - - -
    2016-07-11 - - - -
    2016-07-12 0:04:24 4:00:16 - -
    2016-07-13 - - - -
    2016-07-14 - - - -
    2016-07-15 - - - -
    2016-07-16 - - - -
    2016-07-17 1:29:45 1:30:48 - -
    2016-07-18 - 2:54:53 - -
    Battery capacity history
    Charge capacity history of the system's batteries
    2016-02-28 - 2016-03-03 42,530 mWh 42,157 mWh
    2016-03-03 - 2016-03-08 42,530 mWh 42,157 mWh
    2016-03-08 - 2016-04-08 42,530 mWh 42,157 mWh
    2016-04-08 - 2016-04-16 42,530 mWh 42,157 mWh
    2016-04-16 - 2016-04-21 42,530 mWh 42,157 mWh
    2016-04-21 - 2016-04-30 42,530 mWh 42,157 mWh
    2016-04-30 - 2016-05-04 42,530 mWh 42,157 mWh
    2016-05-04 - 2016-05-18 41,815 mWh 42,157 mWh
    2016-05-18 - 2016-05-25 40,675 mWh 42,157 mWh
    2016-05-25 - 2016-06-01 40,675 mWh 42,157 mWh
    2016-06-01 - 2016-06-08 40,675 mWh 42,157 mWh
    2016-06-08 - 2016-06-15 40,675 mWh 42,157 mWh
    2016-06-15 - 2016-06-22 40,675 mWh 42,157 mWh
    2016-06-22 - 2016-06-29 40,675 mWh 42,157 mWh
    2016-06-29 - 2016-07-06 40,675 mWh 42,157 mWh
    2016-07-07 40,675 mWh 42,157 mWh
    2016-07-08 40,925 mWh 42,157 mWh
    2016-07-09 41,207 mWh 42,157 mWh
    2016-07-10 41,207 mWh 42,157 mWh
    2016-07-11 41,207 mWh 42,157 mWh
    2016-07-12 41,190 mWh 42,157 mWh
    2016-07-13 41,154 mWh 42,157 mWh
    2016-07-14 41,154 mWh 42,157 mWh
    2016-07-15 41,154 mWh 42,157 mWh
    2016-07-16 41,154 mWh 42,157 mWh
    2016-07-17 41,154 mWh 42,157 mWh
    2016-07-18 41,154 mWh 42,157 mWh
    Battery life estimates
    Battery life estimates based on observed drains
    2016-02-28 - 2016-03-03 1:01:49 - 1:01:17 -
    2016-03-03 - 2016-03-08 3:29:09 65:27:24<br><br>24 % / 16 h 3:27:18 64:52:58<br><br>25 % / 16 h
    2016-03-08 - 2016-04-08 3:45:14 105:24:08<br><br>15 % / 16 h 3:43:15 104:28:40<br><br>15 % / 16 h
    2016-04-08 - 2016-04-16 2:05:40 137:26:41<br><br>12 % / 16 h 2:04:34 136:14:21<br><br>12 % / 16 h
    2016-04-16 - 2016-04-21 3:08:08 143:57:01<br><br>11 % / 16 h 3:06:29 142:41:16<br><br>11 % / 16 h
    2016-04-21 - 2016-04-30 3:24:50 148:29:33<br><br>11 % / 16 h 3:23:02 147:11:24<br><br>11 % / 16 h
    2016-04-30 - 2016-05-04 3:53:55 127:46:50<br><br>13 % / 16 h 3:51:52 126:39:35<br><br>13 % / 16 h
    2016-05-04 - 2016-05-18 2:53:35 154:35:04<br><br>10 % / 16 h 2:55:00 155:50:56<br><br>10 % / 16 h
    2016-05-18 - 2016-05-25 - - - -
    2016-05-25 - 2016-06-01 - - - -
    2016-06-01 - 2016-06-08 - - - -
    2016-06-08 - 2016-06-15 - - - -
    2016-06-15 - 2016-06-22 - - - -
    2016-06-22 - 2016-06-29 - - - -
    2016-06-29 - 2016-07-06 - - - -
    2016-07-07 3:10:47 147:52:19<br><br>11 % / 16 h 3:17:45 153:15:35<br><br>10 % / 16 h
    2016-07-08 3:27:01 20:56:51<br><br>76 % / 16 h 3:33:15 21:34:41<br><br>74 % / 16 h
    2016-07-09 - - - -
    2016-07-10 - - - -
    2016-07-11 - - - -
    2016-07-12 1:44:09 374:01:14<br><br>4 % / 16 h 1:46:36 382:48:04<br><br>4 % / 16 h
    2016-07-13 - - - -
    2016-07-14 - - - -
    2016-07-15 - - - -
    2016-07-16 - - - -
    2016-07-17 5:06:02 351:51:46<br><br>5 % / 16 h 5:13:29 360:26:18<br><br>4 % / 16 h
    2016-07-18 - 168:28:21<br><br>9 % / 16 h - 172:34:42<br><br>9 % / 16 h
    Current estimate of battery life based on all observed drains since OS install
    Since OS install 3:09:49 132:52:43<br><br>12 % / 16 h 3:14:27 136:07:01<br><br>12 % / 16 h
    2016-07-19T14:37:19+00:00
    and you will only get a 3 month warranty with the replacement
    its a disgraceful way for microsoft to operate
    2016-07-19T14:27:09+00:00
    I had the same problem with my SP3. Battery just died after 1.5 years. Did a clean install of Win 8.1 and Win 10 hoping it was a software issue. No luck. Sent in for a replacement @ $500+. Waiting for the replacement.
