2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-19T13:55:09+00:00
    As I explained, you must be running Windows 10 with the Feedback Hub installed, when you can paste it into the Run dialogue (WinKey+R).  I've now created a web link that you can use instead which will then prompt you to open the Feedback Hub:
    https://feedbackhub.link/feedback/71/3f578c18-7908-4c51-8a66-6c8523d90c15/
    This issue is not limited to Win10.
    I'm curious about how many of who are affected also use the SP3 docking station (not the new one) as that is how I use mine mostly so actual "battery" only usage is fairly low overall.
    This seems to be gaining some coverage now (thanks to Barb's persistence) so hopefully Microsoft can look through the general telemetry they receive and find the route cause.
    I do not use a docking station, but usually (90%) had the SP3 plugged in when in use. I'm now down to 524mWh full charge. It no longer can hold enough charge to go into sleep mode while I commute home (10min). This is not battery wear/degradation, it's straight up battery failure.
    Agreed, hopefully Microsoft realizes this is not a small problem. SIMPLO should be worried at this point.
    2016-07-19T11:26:34+00:00
    I don't use a docking station (I doubt it's available at where I live at all) but mine stay plugged about maybe 80-90% of the time.  My cycle count was around 73 when I noticed the issue, but there are few people here whose cycle count is around 200.
    Thank you Barb Bowman for bringing some media attention. I really hope Microsoft will take notice sometimes soon.
    2016-07-19T11:16:05+00:00
    2016-07-19T10:03:42+00:00
    The link will open the program but only in the English version of Windows
