2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-31T21:22:58+00:00
    They've just posted the MSI which 'should' lay down this firmware. https://www.microsoft.com/en-us/download/details.aspx?id=38826
    Download and run it. Restart twice after it finishes
    2016-08-31T19:50:12+00:00
    So I continued following the steps and it looks like the results are the same.
    The update screen flashes and then the computer restarts right away. It does this twice and then afterwards it just boots up regularly, skipping the update entirely.
    The status still says it requires a restart to finish installing.
    2016-08-31T19:29:33+00:00
    Mates, My SP3 i7 256 Gb + SIMPLO X898289, previously stuck at 144 mWh first jumped to 35,910 mWh right after the FW, and today I am happy to notice I am at 37,704 mWh.
    I am at 499 cycles. I am not expecting much more increase since my SP3 is a 1.5 year old, but who knows...
    2016-08-31T19:18:49+00:00
    They said to remove the battery driver as well and continue...
