2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-09-01T07:56:29+00:00
    Hi guys, I'm in Japan and my Surface Pro 3 i5 8GB 256GB was an SDI battery. I can only use the device when it is plugged in the AC adaptor, as soon as I pull the AC it switches off. My battery is not detected, so none of the firmware or updates are being installed correctly, every time I start the machine it says installing updates please wait.
    My surface pro 3 is out of warranty and I've just been quoted 80,000 Japanese Yen or 780 US dollars/588 UK pounds for a replacement. That is an absolute JOKE!
    Why do I have to pay almost 800 US dollars to get a battery replaced? Is there an alternative to this madness?
    2016-09-01T01:50:37+00:00
    Ah unfortunately that didn't work either. Every time the progress bar moves up a bit the computer keeps restarting before the update gets a chance to finish.
    2016-09-01T00:55:16+00:00
    They've just posted the MSI which 'should' lay down this firmware. https://www.microsoft.com/en-us/download/details.aspx?id=38826
    Download and run it. Restart twice after it finishes
    Dear Barb
    I have the same problem as Jason.N1.
    I first updated my firmware using Windows Update and followed up the two restart instruction but it didn't work.
    Then I downloaded the firmware manually from the link you provided and installed it but it didn't work either.
    While booting, firmware update progress bar goes near 100% and then device restarts and when I log on I see that the firmware isn't installed.
    By the way I checked the device manager and error code for Embedded Controller Firmware is 14.
    Now my battery status icon in taskbar shows "No battery detected" but when I click on it shows my battery is fully charged.
    I'd appreciate it if you could help me.
    2016-08-31T22:27:53+00:00
    My SP3 with SIMPLO previously at 144mWh is now at 38486mWh.
    I don't know if this helps but I plug the charger at 10% and unplug once it reaches 100%
    Every time is increasing, so in a few days should reach it's maximum capacity, which I hope it will be about 40000mWh
