2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-31T18:57:37+00:00
    Hi Barb,
    Thanks a bunch for getting back to me!
    I was able to do everything up till step 5. However my battery shows "9% available, plugged in not charging"
    so I can't get the battery to show 100% charge. Should I continue with the steps anyway?
    Also i'm not sure if this is part of the problem, but the Surface pro UEFI also has the code 10 error
    2016-08-31T18:26:05+00:00
    IS NOT FIXED ON LGC BATTERY
    2016-08-31T18:25:27+00:00
    I also am still showing 35,910 after about 4 full discharge / charge cycles. I am also feeling like this might be a temporary hardcoded value from the fix. Anyone showing anything higher after updating?
    I am hoping this goes up from there back to close to what it was before the issue presented itself. In april, just before the cliff drop of capacity, mine was at 40,282 which seems about right for wear on a 14 month old battery. I am hoping the lack of real charge cycles since then has not degraded the actual cells too much.
    Does anyone have a decent way to benchmark the current state of the battery in a fairly consistent way? I tried just putting it at 75% brightness and streaming a long looping HD youtube video of a fireplace at fullscreen until the surface died. The video made it to the 4:20 mark. Maybe we could get a common benchmark going and see where we are comparatively.
    -Rob
    2016-08-31T17:49:14+00:00
    they want you to try:
    1. Boot into Windows however you can (doing a 2-button reset as other users in the forum have done, and letting it charge for a bit before trying to boot into Windows should work.)
    2. In Device Manager find the Embedded Controller firmware.  It will show with yellow bang. Open the properties of this firmware and verify the error code – it should say “Code 10”.  If it’s not Code 10, don’t go any further, but post to let us know what you see in Device Manager.
    3. Assuming it was listed with a Code 10 error, tell Device Manager to uninstall the firmware.  It will give you choice to remove/delete the files. Check the box to remove the files and uninstall.
    4. Reboot the system and then come back into Device Manager.  Check to ensure it’s running the older Embedded Controller firmware.  (38.9.50)
    5. Once the older EC is on the system, stop and make sure that the system is showing “100%” charge on the battery.  Once that’s true, go ahead and apply the update again. This should prompt you to restart once the update is done, but don’t choose to restart right away.  Instead, close everything out and tell Windows to shut down (not restart) manually.
    6. Boot on AC power again as you did before.  You should get the splash screen as it tries to apply the firmware update again.  Let us know the results.
