2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-18T17:35:20+00:00
    Surface Pro 3 (Purchased July 2014)
    Information about each currently installed battery
    BATTERY 1
    NAME    X883815
    MANUFACTURER    LGC-LGC
    SERIAL NUMBER    1150752772
    CHEMISTRY    LION
    DESIGN CAPACITY    42,157 mWh
    FULL CHARGE CAPACITY    39,604 mWh
    CYCLE COUNT    569
    Battery capacity history
    Charge capacity history of the system's batteries
    PERIOD    FULL CHARGE CAPACITY     DESIGN CAPACITY
    2015-11-16 - 2015-11-23    42,904 mWh     42,157 mWh
    2015-11-23 - 2015-11-29    42,170 mWh     42,157 mWh
    2015-11-29 - 2015-12-06    41,625 mWh     42,157 mWh
    2015-12-06 - 2015-12-13    40,744 mWh     42,157 mWh
    2015-12-13 - 2015-12-21    40,260 mWh     42,157 mWh
    2015-12-21 - 2015-12-27    40,069 mWh     42,157 mWh
    2015-12-27 - 2016-01-04    39,782 mWh     42,157 mWh
    2016-01-04 - 2016-01-10    39,280 mWh     42,157 mWh
    2016-01-10 - 2016-01-17    39,607 mWh     42,157 mWh
    2016-01-17 - 2016-01-25    39,474 mWh     42,157 mWh
    2016-01-25 - 2016-01-31    39,720 mWh     42,157 mWh
    2016-01-31 - 2016-02-07    41,677 mWh     42,157 mWh
    2016-02-07 - 2016-02-14    43,971 mWh     42,157 mWh
    2016-02-14 - 2016-02-21    44,126 mWh     42,157 mWh
    2016-02-21 - 2016-02-29    44,270 mWh     42,157 mWh
    2016-02-29 - 2016-03-06    44,270 mWh     42,157 mWh
    2016-03-06 - 2016-03-13    44,270 mWh     42,157 mWh
    2016-03-13 - 2016-03-21    44,270 mWh     42,157 mWh
    2016-03-21 - 2016-03-27    44,270 mWh     42,157 mWh
    2016-03-27 - 2016-04-04    44,270 mWh     42,157 mWh
    2016-04-04 - 2016-04-10    44,270 mWh     42,157 mWh
    2016-04-10 - 2016-04-17    44,270 mWh     42,157 mWh
    2016-04-17 - 2016-05-01    44,270 mWh     42,157 mWh
    2016-05-01 - 2016-05-15    44,199 mWh     42,157 mWh
    2016-05-15 - 2016-05-22    43,567 mWh     42,157 mWh
    2016-05-22 - 2016-05-29    43,054 mWh     42,157 mWh
    2016-05-29 - 2016-06-05    42,982 mWh     42,157 mWh
    2016-06-05 - 2016-06-12    42,619 mWh     42,157 mWh
    2016-06-12 - 2016-06-19    42,547 mWh     42,157 mWh
    2016-06-19 - 2016-06-26    41,836 mWh     42,157 mWh
    2016-06-26 - 2016-07-03    41,125 mWh     42,157 mWh
    2016-07-03 - 2016-07-10    40,156 mWh     42,157 mWh
    2016-07-11    40,006 mWh     42,157 mWh
    2016-07-12    39,953 mWh     42,157 mWh
    2016-07-13    39,953 mWh     42,157 mWh
    2016-07-14    39,953 mWh     42,157 mWh
    2016-07-15    39,787 mWh     42,157 mWh
    2016-07-16    39,474 mWh     42,157 mWh
    2016-07-17    39,474 mWh     42,157 mWh
    2016-07-18T14:02:56+00:00
    Please also up vote this feedback item and include the images posted here:
    feedback-hub:?contextid=71&feedbackid=3f578c18-7908-4c51-8a66-6c8523d90c15&form=1&src=2
    Best way to access this item is to copy that link then WinKey-R to bring up the Run... dialogue. Then paste it and click OK.  So far this only has one up vote so is unlikely to appear on their radar.
    I don't understand what you are asking us to do here. The feedback link above is not a valid link. I've run a battery report and posted it on several different places throughout this thread. Where else do I need to post it so it "appears on their radar"?
    2016-07-18T13:54:11+00:00
    Bob, run a battery report (admin cmd prompt, then powercfg /batteryreport) and then upload the results, including the manufacturer of your battery.
    Here's mine once again:
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=3a4cb9bd-9b77-4978-b74b-297dfcd57c1c)![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=ca5a953d-17b7-4021-83c2-0a461320f9b9)
    2016-07-18T13:50:38+00:00
