2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-19T01:57:37+00:00
    I just found out I have the same problem. I'm not one to shy away from legal action. I'd like to see Microsoft do the right thing but we will see.
    2016-07-19T01:35:02+00:00
    Just found out I also have this issue a few days ago.  The decline in battery life started somewhere around 4/2016 and is now at a full capacity at ~5000 mWh.  This is just plain unacceptable and needs to be amended.  In no way should we be the ones to have to pay out of pocket for this.  Any customer service rep that refers to the warranty needs to get their head out of their **** and report this problem to someone who can actually fix it.
    2016-07-18T18:05:47+00:00
    2016-07-18T17:57:27+00:00
    The LGC batteries do not appear to have the issue being discussed.
