2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-18T13:47:26+00:00
    2016-07-18T13:43:47+00:00
    I had this same problem as well.  Since I use this for work, I ended up spending the $450 to send it in and get it replaced.
    You should get your money, or a portion of it back, from the sure to ensue class action lawsuit.
    2016-07-18T11:59:49+00:00
    2016-07-18T10:53:39+00:00
    Sorry but after pasting given over to non-English systems, there is a lack of information on the program, which is to be launched link.
    Is it possible to vote outside the application?
