2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-07-18T10:22:07+00:00
    Battery report
    COMPUTER NAME SURFACE
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.1150 12/09/2015
    OS BUILD 10586.494.amd64fre.th2_release_sec.160630-1736
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-07-18 12:18:14
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1163401732
    CHEMISTRY LION
    DESIGN CAPACITY mWh
    FULL CHARGE CAPACITY mWh
    CYCLE COUNT 85
    Recent usage
    Power states over the last 3 days
    2016-07-15 12:59:00 Active AC 100 % mWh
    13:21:18 Connected standby AC 100 % mWh
    15:17:11 Active AC 100 % mWh
    15:42:19 Connected standby AC 100 % mWh
    16:03:54 Active AC 100 % mWh
    16:20:35 Connected standby AC 100 % mWh
    16:20:36 Active AC 100 % mWh
    16:42:16 Connected standby AC 100 % mWh
    16:44:26 Active AC 100 % mWh
    16:58:12 Connected standby AC 100 % mWh
    17:01:56 Active AC 100 % mWh
    17:14:22 Connected standby AC 100 % mWh
    17:15:47 Active AC 100 % mWh
    17:18:51 Connected standby AC 100 % mWh
    2016-07-17 15:00:13 Active AC 100 % mWh
    15:00:42 Connected standby AC 100 % mWh
    2016-07-18 11:15:09 Suspended 100 % mWh
    11:33:40 Active AC 100 % mWh
    12:17:00 Report generated AC 100 % mWh
    Battery usage
    Battery drains over the last 3 days
    Usage history
    History of system usage on AC and battery
    2016-05-19 - 2016-05-26 0:32:13 0:01:45 68:29:46 15:59:08
    2016-05-26 - 2016-06-02 1:10:24 0:02:33 49:28:40 10:30:13
    2016-06-02 - 2016-06-09 0:40:42 0:01:36 60:07:24 8:30:00
    2016-06-09 - 2016-06-16 0:29:36 - 58:13:28 25:26:05
    2016-06-16 - 2016-06-23 1:02:06 0:32:45 73:30:10 30:58:22
    2016-06-23 - 2016-06-30 0:04:18 - 20:05:48 19:51:57
    2016-06-30 - 2016-07-07 - - - -
    2016-07-08 - - - -
    2016-07-09 - - - -
    2016-07-10 - - - -
    2016-07-11 - - - -
    2016-07-12 - - - -
    2016-07-13 0:00:09 - 9:46:52 -
    2016-07-14 - - 10:50:12 0:38:36
    2016-07-15 - - 3:10:46 9:49:26
    2016-07-16 - - - 23:59:46
    2016-07-17 - - 0:00:29 23:59:17
    Battery capacity history
    Charge capacity history of the system's batteries
    2016-05-19 - 2016-05-26 mWh mWh
    2016-05-26 - 2016-06-02 mWh mWh
    2016-06-02 - 2016-06-09 mWh mWh
    2016-06-09 - 2016-06-16 mWh mWh
    2016-06-16 - 2016-06-23 mWh mWh
    2016-06-23 - 2016-06-30 mWh mWh
    2016-06-30 - 2016-07-07 mWh mWh
    2016-07-08 mWh mWh
    2016-07-09 mWh mWh
    2016-07-10 mWh mWh
    2016-07-11 mWh mWh
    2016-07-12 mWh mWh
    2016-07-13 mWh mWh
    2016-07-14 mWh mWh
    2016-07-15 mWh mWh
    2016-07-16 mWh mWh
    2016-07-17 mWh mWh
    Battery life estimates
    Battery life estimates based on observed drains
    2016-05-19 - 2016-05-26 2:30:43 - 5:37:10 -
    2016-05-26 - 2016-06-02 1:39:47 2:09:27<br><br>742 % / 16 h 4:39:55 6:03:10<br><br>264 % / 16 h
    2016-06-02 - 2016-06-09 1:09:00 0:32:21<br><br>2968 % / 16 h 4:15:58 2:00:01<br><br>800 % / 16 h
    2016-06-09 - 2016-06-16 1:04:30 - 5:31:56 -
    2016-06-16 - 2016-06-23 0:36:12 3:15:44<br><br>490 % / 16 h 4:14:33 22:56:30<br><br>70 % / 16 h
    2016-06-23 - 2016-06-30 0:06:00 - 0:45:36 -
    2016-07-08 - - - -
    2016-07-09 - - - -
    2016-07-10 - - - -
    2016-07-11 - - - -
    2016-07-12 - - - -
    2016-07-13 - - - -
    2016-07-14 - - - -
    2016-07-15 - - - -
    2016-07-16 - - - -
    2016-07-17 - - - -
    Current estimate of battery life based on all observed drains since OS install
    Since OS install 0:13:46 0:47:02<br><br>2041 % / 16 h 4:16:19 14:35:32<br><br>110 % / 16 h
    After disconnecting the power supply tablet turns off immediately.
    2016-07-18T08:29:07+00:00
    Please also up vote this feedback item and include the images posted here:
    feedback-hub:?contextid=71&feedbackid=3f578c18-7908-4c51-8a66-6c8523d90c15&form=1&src=2
    Best way to access this item is to copy that link then WinKey-R to bring up the Run... dialogue. Then paste it and click OK.  So far this only has one up vote so is unlikely to appear on their radar.
    2016-07-18T03:44:35+00:00
    Here's mine:
    2016-07-17T23:12:04+00:00
    Anybody else find that once the battery was below 1000mwh they could not use the SP3 even docked because once the CPU and fan got going the device would shut off?
    Also - my device was docked most of the time - is this the same for everyone else?
    Yes Simon - That's exactly what happened to me.  I run my SP3  docked 90% of the time.  Just over a week ago it started powering down randomly while it was docked.
