2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-16T18:21:19+00:00
    JG,
    The store employee told me my Complete protection plan will cover the replacement unit until my Complete coverage expires next year.
    2016-08-16T18:16:04+00:00
    I installed it the day it came out. Actually, I had two firmware updates come at the same time. I have a full charge capacity now of 144mWh. I don't think it addresses this issue.
    2016-08-16T18:08:42+00:00
    2016-08-16T17:27:27+00:00
    Will your existing Complete protection plan continue to cover the replacement Surface Pro 3, or will you only have a 60 day warranty for the refurbished replacement, like I was told by MS Store?
