2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-16T16:40:26+00:00
    I made an appointment earlier today at a local Microsoft Store.  I explained the dead battery and they gave me a replacement Surface Pro right away.  It took about 15 minutes, and was no issue at all.
    They mentioned they were familiar with the Windows Surface Pro 3 battery problems and replacing them as they came in.
    Although I did have the Complete protection plan, he mentioned that this did not count towards that use because it was their problem.
    So, I found great Microsoft customer service at the store.
    It's a shame the forum is not represented by quality Microsoft customer service.  They could have simply acknowledged the issue and told us the process for replacement.
    If you can, go to your local store for resolution.
    2016-08-16T16:17:59+00:00
    I just recently (last 2 weeks) started experiancing the same issue everyone else has been reporting. After fully charging my Surface Pro 3 the battery only lasts about 45 minutes. I haven't installed anything new on my Surface except for the normal updates and the latest Office Suite. I can't imagine Office 2016 would cause this issue, but that and the normal updates is all that has been installed in the last 2 weeks (and I use it daily).
    2016-08-16T14:18:30+00:00
    I work in IT for a large company with about 160 users. We have probably 60+ users on the surface pro 3 and I have seen this exact issue about 4-5 times in the last year. You did the correct research running the powercfg and from what I have been able to find through my own digging and working with Microsoft customer support was that it was a battery issue. I understand that software may be involved, but with the affected Pro's I had tried completely wiping EVERYTHING off the surface and reinstalling windows and updating from the ground up and still had this same issue coming back. I had them all replaced through Microsoft advanced replacement (which was always super fast). We also had extended warranty's on all the surfaces we bought for the company so there was no extra cost associated.
    2016-08-16T11:57:26+00:00
    I was using a similar method (see my posts on page 66/August 10 in this thread) and had luck increasing my battery's full charge capacity. However after a few days with rising capacity it started decline again. The battery icon would say something like "99%, plugged in, not charging" and the charge had stopped a little short of the previous full charge. I was at nearly 21,000 mWh but now I'm back down to about 17,000.
    I should mention I did not do any complete discharges of the battery, but recharged at various percentage levels. I may try to fully discharge a few times to see if I can get it back up again, but at this point I have pretty much accepted that I must wait for a proper solution.
