2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-16T11:18:44+00:00
    You had previously reported that nothing was working, so hopefully this is good news. From what I have seen, when the full charge capacity at the top of the battery report increases, it is real, e.g. the battery really holds more charge than previously. Also, when the battery capacity remaining in the recent usage section of the battery report shows greater than 100%, as in the table below, that also means the battery has recovered some of its lost charge capacity, even though the full charge capacity at the top of the report does not show the higher capacity yet. The report’s full charge capacity eventually catches up.
    Recent usage
    Power states over the last 3 days
    2016-08-13 12:20:31 Active Battery 18 % 5,814 mWh
    12:55:08 Active AC 7 % 2,409 mWh
    13:33:17 Connected standby AC 11 % 3,648 mWh
    17:19:40 Active AC 105 % 34,215 mWh
    17:22:00 Active Battery 105 % 34,215 mWh
    17:31:27 Connected standby Battery 105 % 34,215 mWh
    The only way to know for certain whether the battery capacity has really improved is to see if the Surface Pro 3 operates longer on battery. After several weeks of declining battery life, a few weeks ago I started to see the full charge capacity in the battery report improve modestly after each discharge-recharge cycle. In most cases the improvement registered right away, but in some cases it showed flat at first and the battery capacity in the recent usage section showed greater than 100%. After several cycles, the improvement in battery life was noticeable. After many more cycles, it was substantial.
    I do not have hibernate shut off as you do. If your surface is not plugged in, that would have the effect of draining the battery completely, or if Windows has a programmed hard stop independent of settings, then to that point. One thing I tried had much the same effect. I restarted my Surface on battery after it shut off automatically at low power, to try to drain the battery completely. I did this several times. On some attempts, it would not reboot, the surface just showed an empty battery icon, and I had to plug it in. On other attempts, it did reboot, and I ran it for several more minutes until it shut down again. I cannot say why it worked sometimes and not others.
    I do not know whether to recommend that others try that. Windows eventually shuts down without a full power off or hibernate, or at least that’s what it appears to do, and at least once, I lost personal settings for one of my programs (that may or may not be related). On the other hand, draining the battery to true zero might have been the trigger event required to reset the battery driver to charge the battery to a higher total capacity. With a sample size of one, I cannot say for certain.
    2016-08-16T11:07:12+00:00
    Also tweet this guy (@IsForAt) although so far he has done f**k all despite the #BatteryGate tweets he has been sent.
    LOL this tweet is so dripping with irony it hurts.
    Brian Hall, YOUR "tablet that can replace a laptop" barely lasted me a little over a year before the battery is effectively dead.  Looking at how much money I spent on my Surface (docking station, type cover, etc.) I now realize it would have been better spent on that "old Apple laptop" because at least that wouldn't be permanently tethered to a power supply.
    It's just shameful how you've handled all of this.
    2016-08-16T08:18:52+00:00
    i am currently trying to gain back the design capacity using the following ways
    1. disable hibernate option completely. disable hibernate after sleep for 4 hours
    2. the system to only either switch or on sleep mode
    3. after use to whatever percentage that i have been using, charge using the normal charger
    4. When the battery is full, check if it is below 100 percent or above 100 percent using battery monitor
    5. if the battery is above 100 percent, shut down and restart surface pro 3 to enable the full charge capacity to increase
    6. if the battery is below 100 percent (maybe 99.9 or 99.6 or 99.5 percent), do not shut down the surface pro 3 and just use the surface pro 3 as usual
    7. after use then charge to full again to see if the percentage can go above 100 percent. continue to repeat the cycle
    anyone have any comments whether how i perform the above will have any negative effect on my surface pro 3 or actually i am just probably lying to myself looking at the full charged capacity?
    Mmmh, not sure to get what you meant by "above" 100%. Did you meant equal to 100 % ?
    Could you please post a picture of your battery report (enter "powercfg /batteryreport" at a DOS prompt, and open the newly created "battery-report.html" saved in Windows/System32) ?
    I yes, please make sure to post the "Battery capacity history" table for us to check a concrete mWh increase.
    Thanks !
    2016-08-16T07:55:45+00:00
