2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
If you’re having trouble charging your Surface, you get a low-battery error, or your Surface turns off when you unplug it, the steps in our Surface battery won’t charge article can help you pinpoint the problem. Should you need any further assistance, please contact us.
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-16T07:03:31+00:00
    Also tweet this guy (@IsForAt) although so far he has done f**k all despite the #BatteryGate tweets he has been sent.
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=a71cacf6-d664-46a3-8f1b-3fe14c6a83f1)
    2016-08-16T06:49:39+00:00
    Greg now loads grocery carts at the end of the register conveyor belt.
    What would be nice if Greg could come to my business meetings and explain to my clients why I've had to arrive 30 minutes early and scramble around on the floor hooking up to power outlets before caressing my SP3 into staying powered on.
    On the positive side, glass half full and all, it does create a talking point resulting in many more people being aware that under no circumstances should they ever consider buying a Surface branded product.
    Customer service is about holding the customers hand and keeping them informed even when there is little or no progress.  It is about building confidence, even in the worst of times like this, that something is being done and that no matter what it will be resolved either through a software update or a product recall/replacement.
    Sadly Microsoft, and in particular the Surface team, are spectacularly failing at that simple task which really takes very little effort to get right.  I've turned around situations where customers were on the brink of cancelling a contract into a letter of appreciation for all the effort put into restoring that faith even though it took time and things weren't always perfect (I just made sure they knew about problems by proactively informing them instead of reacting to them).
    I had planned to purchase the Surface Pro 5 and if released the Surface Phone but not now.  The Surface brand will be forever tarnished by this and the horrific Surface Pro 4 & Surface Book launch catastrophe.
    I know Mary Jo Foley and Paul Thurrott and continually chasing Microsoft and even they can't get any information out of them.  It is also mentioned on Windows Weekly each week.  Please also use the hash tag #BatteryGate on social media as that seems to be helping spread the word.
    2016-08-16T06:48:28+00:00
    how about you help me? I can't keep my computer on!! I pay a premium for a device that can't even stay on!!
    2016-08-16T02:30:37+00:00
    same issue...just posting to be counted.
    If you want to be counted, click the ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=0fe6a21f-0aee-406f-8424-fdfc3ff32370) on the first post.
