2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
If you’re having trouble charging your Surface, you get a low-battery error, or your Surface turns off when you unplug it, the steps in our Surface battery won’t charge article can help you pinpoint the problem. Should you need any further assistance, please contact us.
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-15T23:04:59+00:00
    same issue...just posting to be counted.  11 minutes of battery life - frustrated beyond belief.
    Battery life estimates
    Battery life estimates based on observed drains
    2016-08-10 0:15:18 16:01:24<br><br>100 % / 16 h 2:30:04 157:05:40<br><br>10 % / 16 h
    2016-08-11 - - - -
    2016-08-12 0:09:17 0:35:25<br><br>2711 % / 16 h 1:40:19 6:22:42<br><br>251 % / 16 h
    2016-08-13 - - - -
    2016-08-14 0:29:11 - 5:43:36 -
    Current estimate of battery life based on all observed drains since OS install
    Since OS install 0:11:49 4:10:56<br><br>383 % / 16 h 2:30:48 53:19:53<br><br>30 % / 16 h
    2016-08-15T22:43:01+00:00
    I bought the new 65w power brick (the one that came with the pro 3 is around 30W), and the new one does seem to keep my surface pro 3 up even under high load.
    I order it from Amazon (If you buy from Amazon make sure the seller is Amazon; from the comments it looks like there's some 3rd party parts listed under same ASIN by other sellers).
    It's listed as
    "Microsoft Surface Power Supply 65W V4"
    Item model number: Q4Q-00001
    ASIN: B01698T1TC
    Does anyone have the new dock? I'm wondering if that puts out the same 65W.
    2016-08-15T22:22:55+00:00
    Does this mean that Microsoft is no longer working on a potential solution?
    No. It means they are working on a solution that best suits Microsoft. If it were a driver or firmware issue, they could have provided an option to roll back to a previous version that didn't cause the problem, but haven't.
    They either cannot roll back to a battery friendly version because their upgrade plan isn't fault tolerant, there is no fix, so they are stalling in the hope that time will make the problem go away, as users will buy replacement devices, or they have concluded it is a hardware issue that would be more expensive to recall, than to reach a financial settlement in a class action law suit.
    By the time a law suit is settled, most SP3 users will have moved on from their, by then, expensive paper weight.
  4. Deleted
