2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
If you’re having trouble charging your Surface, you get a low-battery error, or your Surface turns off when you unplug it, the steps in our Surface battery won’t charge article can help you pinpoint the problem. Should you need any further assistance, please contact us.
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-15T21:14:56+00:00
    Same issue here. This is obviously a hardware defect that Microsoft should address instead of asking us to pay $450 to send it in.
    2016-08-15T21:13:22+00:00
    we still don't know yet.
    2016-08-15T20:06:22+00:00
    Does this mean that Microsoft is no longer working on a potential solution?
    2016-08-15T19:55:31+00:00
    They've removed the threads that were incorrectly merged.
