2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
If you’re having trouble charging your Surface, you get a low-battery error, or your Surface turns off when you unplug it, the steps in our Surface battery won’t charge article can help you pinpoint the problem. Should you need any further assistance, please contact us.
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
  1. Deleted
    2016-08-15T19:32:27+00:00
    Been a lot of activity for some reason on this thread today. Just as a reminder for those who are new to the problem and don't want to scroll all the way back through the thread - many of us have found the only workable solution is to disable the battery driver. Of course you are limited to power cord only (but you already are or you would not be on this site) and the power cord cannot be through the docking station but only directly to the SP3. Mine has been pretty consistently working with that setup. And then you can purchase a portable AC charger (about $200) if you want to be away from an outlet.
    None of this eases the frustration that MS has been well aware of this problem for quite some time and has apparently made the decision that a fix is not economically in their interest. Good luck.
    2016-08-15T18:46:31+00:00
    All I can advise is going to the store. Call first and make an appointment if you can. A couple of folks have had good luck getting a sympathetic person to exchange for a refurb. And others have not been so lucky.
    My warranty is good until next February (Microsoft Complete), so they shouldn't give me too much grief about swapping it out.
    Thanks for the advice.
    2016-08-15T17:53:35+00:00
