2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
If you’re having trouble charging your Surface, you get a low-battery error, or your Surface turns off when you unplug it, the steps in our Surface battery won’t charge article can help you pinpoint the problem. Should you need any further assistance, please contact us.
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-15T17:49:15+00:00
    I sent THAT issue in yesterday to the folks that run the Community Moderator
    program. It's easy to merge thread, but hard to split them back up. I have no
    idea why the paid staff took the old threads that weren't related and merged
    them. I checked on the issue today and was told it was escalated.
    >>Today the messages in this thread appear merged with messages from other threads. Is this a bug, or was it done intentionally? The first message in this thread is dated May 11, 2016, and that is the message that has anchored this thread all along.
    2016-08-15T17:23:27+00:00
    I've UNmarked it. I have no idea why this was marked as an Answer. I'm well
    aware that customers posting here have had no updates since that was posted 7/26
    and that there are more and more folks unable to turn their SP3's on even when
    plugged in.
    I'm also unable to get any information from Microsoft on the status of this
    issue.
    Barb, Greg, Satya Nadella, Ferris Bueller, anybody, is there still any reason to be hopeful about a software fix to this issue?
    My SP3's battery life is about 30 minutes at this point and degrading fast.  I checked the battery report, it's a SIMPLO of course.  The silence is really the worst part about all of this.  As far as I know, Greg's post was the last comment on the record from anyone at Microsoft.  Did the lawyers gag everyone or does the silence mean there is no fix coming and I should go ahead and drive 1 1/2 hours to the nearest Microsoft store and hope that they'll swap my Surface out for a refurbished one?
    I really love my SP3, but the way the SIMPLO battery problem is being handled really makes me think twice about ever buying another computer from Microsoft.
    Please, Microsoft, at least say something!  I don't even care if it's bad news, any news would be appreciated.
    2016-08-15T17:11:13+00:00
    Thanks for unmarking that message, as it is not an answer.
    (Edit 8/16: The rest of this message describes a problem with unrelated messages appearing in this forum. That problem has since been corrected.)
    Separately, to a Microsoft forum moderator:
    New today: the first reply in this thread is a message from whady dated July 1, 2014 (msgid=b0a64059-95d7-48ce-9de7-4ba6c962053b), which logically makes no sense.
    It appears that the first reply actually originating on this thread is from Brian_D16 on page 12 (msgid=2bf842ba-6e5e-4bb5-9388-848d6f220203).
    2016-08-15T16:25:35+00:00
    plugged in.
    issue.
