2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-16T19:02:29+00:00
    I agree with you.  However, I think the biggest problem most of the people in this thread have is that Microsoft has gone completely silent about this issue and is then proceeding to charge people over $400 to replace the batteries out of warranty.
    Is there a good reason why they're not at least letting us know that they are still testing a firmware patch?  That would really go a long way with people.
    2016-08-16T18:49:40+00:00
    For transparency, I'm a former MSFT PM and have experience running a maintenance release, though I did this within Office. For many reasons, you typically don't publicly admit an issue until you have a fix or some sort of final resolution for it.
    I'm sure if there's a firmware patch in the works, it's going through extended testing. The absolute worst thing that could happen is a patch that makes things worse or bricks some small percentage of machines. That would be truly disastrous. I'd rather wait for a solid patch than quickly get a half-baked patch any day.
    2016-08-16T18:40:47+00:00
    Oh, I know. Of course it doesn't. It's total baloney.
    I was just pointing out that it feels like a corporate countermeasure ("We here at MSFT think you should write this article...").
    2016-08-16T18:24:50+00:00
    Agree it does not seem to address the problem. I also installed the update and also have a full charge capacity of 144mWh. Still need to be tethered full time to power.
