2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
If you’re having trouble charging your Surface, you get a low-battery error, or your Surface turns off when you unplug it, the steps in our Surface battery won’t charge article can help you pinpoint the problem. Should you need any further assistance, please contact us.
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-10T12:28:58+00:00
    I've been trying to see if I can get the capacity on my Surface Pro 3 to improve but seems I've only made it drop even further (I won't be continuing since I'm worried it will soon drop below being able to use my SP3):
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=b7dc7d20-f782-435d-a929-a9849e426b50)
    2016-08-10T08:22:30+00:00
    This is exactly what I did after I wrote the post:
    Starting point: full capacity 19,319 mWh, battery 100%
    1. Plugged out the power, use on battery until 10%.
    2. Restarted Surface and plugged in power, used it as normal while charging until 100% (actually 101% according to BatteryInfoView) - full capacity reached 19,650 mWh
    3. Plugged out power, used it on battery for a while until I went to bed. Only pressed the sleep button this time.
    4. Plugged in and turned it on, battery was about 65%
    5. Charged until full (101,6%), full charge capacity is now 20,003 mWh
    Looks like this time it didn't make a difference if I let the battery go to 10% or 65%, the gain in mWh is almost the same. I'll try a few of these cycles today with different levels of battery discharge.
    edit: Left out that I restarted the Surface in 2)
    2016-08-10T06:15:37+00:00
    I have tried to contact the uk legal team but my email got sent to global escalation in the US.
    So I am hoping that anybody with experiance of proscuting  a uk small claim via the courts can offer some advice. I beleive there is enough evidance in this thread to demostrate that the warrenty repair should have been free.
    Any help gratefully received
    Simon
    2016-08-10T01:20:54+00:00
    Hello Greg,
    Thank you.  Do you have an update?
    My fully charged capacity plunged two weeks ago from 30k mWh to 4k mWh and it now lasts 7 minutes when charger is disconnected.
    thanks,
    joseph
