2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
If you’re having trouble charging your Surface, you get a low-battery error, or your Surface turns off when you unplug it, the steps in our Surface battery won’t charge article can help you pinpoint the problem. Should you need any further assistance, please contact us.
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-10T14:07:23+00:00
    @DatabaseJase asked again yesterday for an update on this. still no update from MS (just so you know we haven't forgotten) — Mary Jo Foley (@maryjofoley) August 10, 2016
    2016-08-10T13:58:51+00:00
    I have a SP3 & my battery is fine ~ so I am wondering:
    1. Is this only when charging from the docking station? I have not
    2. Is this the i7?  Mine is not
    3. Only purchases in Dec 2014 batch? I bought in Aug 2014
    This might narrow it down to why there is a problem.
    2016-08-10T13:49:47+00:00
    I'm not sure if this has been discussed in the thread already (at 64 pages long I could have missed it), but an issue I didn't notice until my SP3's battery capacity fell below 300mWh is that when it is under heavy load (including when it is starting up) it draws more power than the AC adapter can provide and the battery had gotten to the point where it was just barely able to cover the shortfall.
    To avoid reaching a point where the Surface was unable to boot-up, I set the "Maximum processor state" to 65%, which seems to keep the system within the limits of what the AC adapter can provide. This option is not available by default in the Power Options for the Surface. However, adding the registry key below will make the option visible in the advanced power options menu.
    HKLM\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\54533251-82be-4824-96c1-47b60b740d00\bc5038f7-23e0-4960-96da-33abaf5935ec
    Add: DWORD
    Value Name: Attributes
    Value Data: 2
    2016-08-10T12:37:20+00:00
    I also have a SP3 with a SIMPLO battery that is completely dead. Can't even unplug it to move - it powers off immediately. Running the powercfg command shows the battery started to deteriorate back in March which is about 15 months after I bought this from Best Buy.
