2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-10T00:58:05+00:00
    hi, can you let me know how you do it? I tried to use the following steps :
    1. discharge to about 40%
    2. switch off surface pro 3
    3. allow it to charge to full (at least I think it's full) - put in on charging for at least 2 hours since it is at 40% battery level
    4. leave it overnight unplugged and switched off
    5. turn it on in the morning
    To my surprise the battery wear level is even worst than before. I didn't recover any, but it has gotten worst....
    2016-08-09T21:17:18+00:00
    It does not fix it, already tried both the Windows 10 anniversary update, then the firmware update. No joy.
    2016-08-09T21:16:12+00:00
    How will we be notified of a solution? We paid a lot of money for a laptop replacement that can no longer be unplugged!
    2016-08-09T21:12:59+00:00
    I would like to be notified of a solution. My Simplo battery now lasts only a half hour. I completed the Windows 10 Anniversary update and then the firmware update, no improvement for the battery life.
    Where and when will a solution be posted? I don't want to spend $99 for a support chat to find out.
