2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-09T20:10:04+00:00
    I am experiencing something similar. I read about the battery degradation on another forum and checked my own battery log. This was end of July and my full charge capacity was then at 13292 mWh capacity:
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=f76a0e7e-37be-43e2-91a2-c1869551207d)
    What's interesting is it remained on 13292 mWh in the last week of July and until August 2nd. After I installed the Anniversary Update it has actually started to increase (new screenshot as the log is erased when installing AU):
    ![](http://fud.community.services.support.microsoft.com/Fud/FileDownloadHandler.ashx?fid=e99f71eb-0b22-469a-a3fd-139ed823ca17)
    It seems every time the Surface is fully charged after being used on battery for a while, the full charge capacity increases with a few hundred mWh. Right now it's at 19319 mWh, which is after using it on battery and then recharging it fully 2 times since yesterday when it was 17481 mWh. I don't think it makes any difference whether I have the Surface on or off while charging, but I do feel that it helps discharging the battery <10% before recharging (can't confirm this yet though). I was only aware of this development yesterday so I haven't had time to experiment a lot.
    2016-08-09T19:27:50+00:00
    I am having this exact issue. I have had the overheating issue in the top right corner since i bought the thing, but now the battery on a FULL CHARGE only lasts about 2.5 hours total. This is unacceptable. I couldn't send it in during warranty since I NEEDED it for school. Now that I don't need it all the time, my warranty is up.
    2016-08-09T18:52:38+00:00
    my surface pro 3 also doesn't hold any battery charge. Plugging to the power it charges the battery(100%) in 20 seconds, but as soon as I unplug the power cable the surface goes off.
    It's impossible a battery doesn't accept any charge in such short time, so I really believe it should be a driver/software issue.
    Any news from when the new update will come out to sort out this issue?
    Jorge
    2016-08-09T16:43:00+00:00
    NOTICE* * *  The Windows Update 1607 will delete your battery power history in   powercfg /batteryreport.  It also changes the set point where the system shuts down due to low battery.
