2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-08T17:28:15+00:00
    Hi Greg, any update on this issue or date when we should look for a fix?
    2016-08-08T16:59:09+00:00
    Strange how they can assign resource to moderating unfavourable reviews but not to keeping existing customers with faulty equipment informed of progress.
    Commercial suicide.
    2016-08-08T16:57:59+00:00
    So I've been using the process outlined by juanmac way back on page 15 (running the battery to almost dead and then recharging), and I have seen my battery recover quite a bit since then. I haven't been able to do this every day, but I do it as much as I can.
    Back then my battery was somewhere around 18,500 mWh, and now it is at 27,672 mWh. I plan on keeping doing this as much as I can to see if I can get it right back to 42,157 mWh.
    2016-08-08T16:47:11+00:00
    I reached out to the law firm. They replied asking basic info like when and where I purchased it, how much, the state I lived in when purchasing it and now, and my phone number.
