2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-08T16:38:29+00:00
    To the person who was able to receive store credit from Best Buy for their out of warranty SP3, would you mind sharing the BB store location?
    My friend and I went to a local BB store here in Northern California and they had no clue but did ask which BB store had this "recall" going. They wanted to call for more information.
    If we can get some more information on this BB recall, that would be great.
    Thank you.
    2016-08-08T16:28:21+00:00
    Mine is at least not totally dead yet but same result. August 1 update does nothing for my simplo battery that is now reported at 380mwh.  What a nightmare.
    2016-08-08T16:06:29+00:00
    I just wanted to send you an update concerning my Surface Pro 3. It had been running at 144 mWh at full charge. The other day I upgraded the OS to the latest version on the Insider Fast Track. All went well, but the firmware update (8/1/2016) failed due to battery being at less than 40% charge. I tried again and the second time the firmware updated successfully. During the entire upgrade process the SP3 was connected to the stand alone charger since the docking station charger is too unpredictable. I continued working on the SP3 for 2 hours and then left it running. The next morning when I went to the SP3 it was off and refused to start. The detachable keyboard would not light up. It did not respond to the power button or the power button with the up volume held down. I have tried each day to get the SP3 to work, but it is now completely dead. I know Microsoft believes the problem to be a software issue, but at this point there is no way to boot the SP3. The cord of the standalone charger does light up when attached to the SP3 and when the power button of the SP3 is pushed the light will blink once 30 seconds later. Hopefully Microsoft has a plan for rebooting the effected computers that are now completely dead in order to install the new software.
    I suspect we have already seen the response we are going to get....
    https://www.youtube.com/watch?v=zOXtWxhlsUg
    2016-08-08T16:00:50+00:00
    Yes you're right. I did see my review getting published online after an email confirmation, but looks like it got taken down. They aren't censoring 1 star reviews in general, just only 1 starred reviews with battery issues. I did see a 2 star review that points to this link.
