2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-08T18:31:18+00:00
    This is 100% through the SP3 docking station. In fact, I have literally never used the supplied power cord with my SP3, I have always charged it with the docking station.
    2016-08-08T18:29:47+00:00
    So I've been using the process outlined by juanmac way back on page 15 (running the battery to almost dead and then recharging),
    Do you mean to almost dead or 50% as he outlines? Also, do you unplug after reaching 100%?
    Thanks.
    2016-08-08T18:17:48+00:00
    Please can you confirm which charger you've been using, directly with the supplied power cable or indirectly through a docking station?
    2016-08-08T18:08:17+00:00
    peking china
    just out of warranty for 3 weeks
    by it from a reseller
    I contact the MS online support and show them my battery report which generated under warranty. then they make an new order to fix my equipment
    and when I got my SP3 back,I found it's a refurb one
