2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-01T10:55:00+00:00
    Let us all hope that what appears to be a software problem did not cook all our batteries to the point they have failed and this is now a hardware issue.
    With the information from the people rebooting into Windows 8.1, it sure seems to be hardware.
    Yeah, it could be firmware.  Let's hope so.
    Maybe they are waiting on a boat that is to bring over enough replacements so that they can do a recall.
    2016-08-01T04:04:49+00:00
    My surface pro 3 is now out of warranty and the battery last about 15 minutes and shuts down.   I tried my best to stick with Windows but it looks like they have made up my mind.  My next purchase will be MAC and I won't come back.
    Hi RGill64,
    Thank you for sharing your concern in our Community page.
    We are currently working on this and looking for a better solution to address this as soon as possible. To get the latest update for this issue, please refer to the link found below.
    Hope this helps.
    2016-08-01T02:33:00+00:00
    I have updates set on automatic. It would be interesting to map an ovelap with a firmware update that could have caused these symptoms. A battery can bounce back from this once the correct software/firmware is in place. Fingers crossed.
    M
    2016-08-01T02:25:02+00:00
    Exactly my story. Hoping its not planned obsolescence, via firmware, anything sinister like that. Had it happen in Epson printers which worked fine until updated. If it was a hardware issue, Microsoft would be done. Look at the last batch of Sony laptop recalls due to battery issues. Fsiling bateries can have catastrofic phisical manifestations that could render the units unsafe. That would mean a recall and a sad end to a lot of seemingly great ideas made into products.
    Hoping its software, firmware, Its Microsoft, if anyone can figure out a fix I think they can...
