2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-01T15:53:23+00:00
    Greg/MSFT... Add me to the list. Here's my battery report
    Battery report
    COMPUTER NAME XXXXXXXXXXXXXXXX
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.1450 05/27/2016
    OS BUILD 14393.0.amd64fre.rs1_release.160715-1616
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2016-08-01 11:47:48
    Installed batteries
    Information about each currently installed battery
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1163401732
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 1,178 mWh
    CYCLE COUNT 145
    Recent usage
    Power states over the last 3 days
    2016-07-29 12:10:00 Active AC 100 % 1,246 mWh
    13:00:22 Connected standby AC 100 % 1,246 mWh
    13:00:28 Connected standby Battery 100 % 1,246 mWh
    13:00:29 Active Battery 100 % 1,246 mWh
    13:00:34 Connected standby Battery 95 % 1,186 mWh
    13:02:29 Connected standby AC 90 % 1,125 mWh
    13:02:29 Active AC 90 % 1,125 mWh
    13:02:35 Connected standby AC 90 % 1,125 mWh
    13:02:45 Active AC 91 % 1,132 mWh
    14:14:00 Suspended 100 % 1,246 mWh
    2016-07-31 21:22:34 Active AC 100 % 1,178 mWh
    23:11:18 Connected standby AC 100 % 1,178 mWh
    23:23:00 Suspended 100 % 1,178 mWh
    2016-08-01 10:17:57 Active AC 95 % 1,117 mWh
    11:45:00 Report generated AC 100 % 1,178 mWh
    Battery usage
    Battery drains over the last 3 days
    2016-07-29 13:00:28 Connected standby 0:00:00 - -
    13:00:29 Active 0:00:05 5 % 60 mWh
    13:00:34 Connected standby 0:01:54 5 % 61 mWh
    Usage history
    History of system usage on AC and battery
    2016-06-10 - 2016-06-17 6:46:33 23:21:42 17:16:41 23:09:30
    2016-06-17 - 2016-06-24 4:02:48 18:22:42 40:29:00 24:22:18
    2016-06-24 - 2016-07-01 5:16:50 25:24:11 35:00:44 58:45:14
    2016-07-01 - 2016-07-08 1:38:33 9:26:34 34:52:45 95:51:39
    2016-07-08 - 2016-07-15 2:47:49 7:56:29 36:50:56 16:58:15
    2016-07-15 - 2016-07-22 2:27:47 6:37:26 48:58:52 22:14:04
    2016-07-23 - - 10:06:51 13:25:49
    2016-07-24 - - - -
    2016-07-25 0:01:24 0:30:26 6:43:54 0:57:53
    2016-07-26 0:01:35 0:08:30 10:04:52 0:18:07
    2016-07-27 0:00:03 0:00:03 7:58:47 0:16:00
    2016-07-28 0:01:53 1:18:37 8:18:05 0:04:47
    2016-07-29 0:00:05 0:01:52 4:49:13 0:10:42
    2016-07-30 - - - -
    2016-07-31 - - 1:48:43 0:11:41
    Battery capacity history
    Charge capacity history of the system's batteries
    2016-06-10 - 2016-06-17 21,896 mWh 42,157 mWh
    2016-06-17 - 2016-06-24 18,559 mWh 42,157 mWh
    2016-06-24 - 2016-07-01 14,273 mWh 42,157 mWh
    2016-07-01 - 2016-07-08 10,552 mWh 42,157 mWh
    2016-07-08 - 2016-07-15 7,459 mWh 42,157 mWh
    2016-07-15 - 2016-07-22 4,824 mWh 42,157 mWh
    2016-07-23 2,804 mWh 42,157 mWh
    2016-07-24 2,804 mWh 42,157 mWh
    2016-07-25 2,367 mWh 42,157 mWh
    2016-07-26 1,884 mWh 42,157 mWh
    2016-07-27 1,486 mWh 42,157 mWh
    2016-07-28 1,426 mWh 42,157 mWh
    2016-07-29 1,304 mWh 42,157 mWh
    2016-07-30 1,246 mWh 42,157 mWh
    2016-07-31 1,238 mWh 42,157 mWh
    Battery life estimates
    Battery life estimates based on observed drains
    2016-06-10 - 2016-06-17 3:00:15 40:48:51<br><br>39 % / 16 h 5:47:03 78:34:52<br><br>20 % / 16 h
    2016-06-17 - 2016-06-24 2:23:29 49:52:23<br><br>32 % / 16 h 5:25:55 113:17:16<br><br>14 % / 16 h
    2016-06-24 - 2016-07-01 2:01:34 35:57:59<br><br>44 % / 16 h 5:59:03 106:13:52<br><br>15 % / 16 h
    2016-07-01 - 2016-07-08 0:55:59 18:58:31<br><br>84 % / 16 h 3:43:41 75:48:36<br><br>21 % / 16 h
    2016-07-08 - 2016-07-15 0:54:01 16:26:41<br><br>97 % / 16 h 5:05:22 92:56:39<br><br>17 % / 16 h
    2016-07-15 - 2016-07-22 0:31:52 7:17:13<br><br>220 % / 16 h 4:38:36 63:40:53<br><br>25 % / 16 h
    2016-07-23 - - - -
    2016-07-24 - - - -
    2016-07-25 0:04:41 0:57:29<br><br>1670 % / 16 h 1:23:28 17:03:55<br><br>94 % / 16 h
    2016-07-26 0:04:27 0:11:27<br><br>8384 % / 16 h 1:39:55 4:16:19<br><br>375 % / 16 h
    2016-07-27 0:00:24 0:01:04<br><br>90000 % / 16 h 0:11:34 0:30:32<br><br>3144 % / 16 h
    2016-07-28 0:04:31 1:50:59<br><br>865 % / 16 h 2:13:53 54:41:25<br><br>29 % / 16 h
    2016-07-29 0:01:48 0:39:54<br><br>2406 % / 16 h 0:58:33 21:30:03<br><br>74 % / 16 h
    2016-07-30 - - - -
    2016-07-31 - - - -
    Current estimate of battery life based on all observed drains since OS install
    Since OS install 0:08:51 2:21:37<br><br>678 % / 16 h 5:16:53 84:28:32<br><br>19 % / 16 h
    2016-08-01T15:40:23+00:00
    Hello everyone,
    We are aware of some customers reporting a scenario with their Surface Pro 3 batteries in which the system is reporting lower battery capacity than expected. We’ve isolated this to a limited number of customers experiencing this issue.
    Based on our investigations we can confirm that it is not an issue with the battery cells, and we believe this is something that can be addressed via software.
    We’re working through the details of how we deliver that.
    Thank you all for the details you've shared here,
    Greg
    Greg,
    Any update regarding the software update for the Surface Pro 3 battery issue?
    Thank you,
    Robert
    2016-08-01T14:20:35+00:00
    Just adding my stats to the thread. Battery was fine until April 2016. With only 144mWh capacity as of July 29, my SP3 Pro is now unusable unless it is plugged directly into the AC. I can't even use my docking station, so that investment was wasted too.
    Installed batteries
    NAME X898289
    MANUFACTURER SIMPLO
    SERIAL NUMBER 1161370116
    CHEMISTRY LION
    FULL CHARGE CAPACITY 144 mWh
    CYCLE COUNT 108
    2016-08-01T13:57:49+00:00
    As per Barb, I contacted support and they waived the $99 fee (thanks Barb!).  However, after spending 2 hours on the phone with support, I have no improvement in my battery life.  They've escalated the issue to a higher support level and are supposed to get back to me in 2-5 days.  Will post again if I get any relief.
