2016-05-11T07:37:37+00:00
2016-07-26T21:31:16+00:00
Hello everyone,
Thanks again.
Greg
Updated 8/29/16.
1,459 additional answers
    2016-08-01T02:22:46+00:00
    2016-08-01T02:12:05+00:00
    It could be a firmware issue. My battery history shows steady charge, right up until April, when it dramatically fell off. If I upgraded the firmware in April, that would explain it and negate the operating system.
    2016-08-01T01:36:48+00:00
    Hey, I tried the same solution. Refreshed win 10 and reinstalled oroginal win8.1 default. No go. Same problem.
    A far as software, im thinking they may mean more in the lines of firmware or bios updates or the sorts rsther than juat drivers.
    I wonder if there is anyone out there, that tid not perform any firmware updates on their unit, that may have started the issue back in April or May. Since win10 updates itself it may be hard, but maybe the issue can be traced to a firmware or bios update that didnt take into account the Simplo brand batteries and their peculiar behavior.
    I am really hopeful this can be worked out, as with a cord my surface seems castrated.
    Hoping its the software.
    Anyone out there with no firmware updates?
    2016-08-01T00:24:14+00:00
    I contacted these attorneys and would suggest that others do the same. Unbelievable how long this has gone on and how poorly MS has handled this.
    http://www.classlawdc.com/2016/07/26/migliaccio-rathod-llp-investigates-microsoft-surface-pro-3-battery-failures/
    I have experienced the same situation as everyone here in this forum. Surface Pro 3 with SIMPLO battery. Full battery capacity in March 2016, warranty expired in March 2016, battery capacity started declining in April 2016 to the point where I now cannot use the tablet at all, much less as a portable. I have made 3 separate inquiries to MS Customer Support, twice being instructed to disable, uninstall, reinstall the battery driver (did not correct the issue either time), and the third being told to send it in for repair/replacement for $550 dollars. I had the call escalated and was told to expect a call or email from a supervisor or higher level agent. This last time was over a week ago and I have yet to receive that call or email. I am beyond unhappy and disappointed with Microsoft's failure to address this rampant, very much not "limited" issue. I had considered myself a loyal customer until this situation was handled the way it has been
