Teams for Android does not work with Bluetooth.
2022-12-06T00:51:43+00:00
Teams will not recognise Bluetooth headphones when joining calls.
I have tried restarting, clearing cache, clearing storage and reinstalling. I have tried multiple different models of headphones from completely different manufacturers. I have tried different phones.
This is not a user issue. This is an issue with the application. Several posts have been made.
Please fix it.
EDIT: the 'Nearby Devices' permission will fix this issue in most cases. For me, it worked temporarily (for one call) and then reverted to the same issue. However, the issue does now seem to be fixed - I have had consistent success for about 2 months now. I am assuming that a recent update to the app has fixed an issue that was causing this.
Microsoft Teams | Microsoft Teams for business | Meetings and calls | Audio and video
2023-06-14T03:03:30+00:00
Hi Chris,
I had the same problem, and I noticed it was because of the permission setting of TEAMS.
I reinstalled Teams and accepted the "Nearby devices." access and it works now.
Sabrina
90 additional answers
    2022-12-06T01:45:30+00:00
    Thanks for the prompt response.
    This is quite a foolish suggestion, but I have tried it and it doesn't work.
    In addition to this, please consider that requiring users to perform such actions rather than improving your application to be on par with basic functionality provided by competitors is a strange way to approach this problem.
    Please raise this with the product owner and development team as a critical issue and update the community on the status of this issue by firstly acknowledging it rather than pushing it to users, and providing meaningful updates on actions taken towards resolution. This is a development issue, not a user issue.
    Bluetooth being unusable on Android devices is a serious flaw.
    2022-12-07T05:27:27+00:00
    Jayzar, thanks for the suggestion and your continued effort to help.
    Whilst these suggestions may work in some scenarios (they didn't for me in this case), they are not really acceptable solutions and are only temporary workarounds at best.
    These headphones work flawlessly with teams on windows and on ios.
    Suggesting they are not compatible with MS Teams is misleading: the MS Teams android application is not compatible with these headphones, and if the list you have shared is accurate then the application does not even support basic airpods.
    It is not a limitation of the headphones (which use the same bluetooth protocol as any other modern headset). This is a serious flaw. Android users are more than half of the mobile device user base. Competing apps like Zoom and Discord have no issue picking up the peripherals attached to a device. The resources available to these development teams would be a fraction of what Microsoft has available.
    I have raised a support ticket already. Unfortunately as an end user that is the end of my ability to interact with a global conglomerate like Microsoft. Whilst this may be a community forum and you are not a microsoft employee, your profile suggests you are contracted and paid by them to provide this support service.
    I would encourage you to raise a support ticket through mechanisms available to you which are more likely to be seen by someone.
    In future I would also encourage you to think more critically about the advice and support you are giving, and try to avoid solutions that basically suggest the user should buy another device because application has an unresolved (and unacknowledged) issue. The issue lies with the application and you should be either escalating this through mechanisms available to you or directly acknowledging this known issue an pointing users to the feedback hub.
    I think we are at an end here in relation to moving forward any further. I am hopeful, but not optimistic, that anyone will even read my feedback ticket, but it seems that is the only practical option available.
    2022-12-15T16:10:24+00:00
    I have the same issue on my samsung note10+.
    Bluetooth as an option has disappeared from my phone in Microsoft Teams in the last week or so.
    Further even when using my device without bluetooth - it doesn't work and I can hear the conversation, but I cannot join in.
    Terrible when I'm on the road and I don't want to try to be typing into the chat!
    2023-01-09T08:12:01+00:00
    From what I think was an issue for me there is that after one of the Android updates, the permissions changed - you need to go to settings, app management, find teams and from there go to permissions. It will probably have nearby devices permission turned off. After adding that permission it should be able to just use the headset.
