yeah ive googled it and seems to be a really common problem with 2070 and 2080 gpu. ive tried a few suggestions, but lets see how it goes. ive reinstalled the drivers so hopefully its just a problem nvidea need to sort with an update :S
Custom built problem
my pc crashed while just watching twitch tv, all the graphics went really low quality then whole pc crashed, had to restart.
i installed geforce experience and as it was doing the update driver, pc crashed and after playing rust, my task bar all went black, i couldnt even see the time.
i have run windows memory test which said no faults, ive done chkdsk and that says no errors.
event viewer shows a critial error, errors and warnings.
critical is:
- <Event xmlns="**http://schemas.microsoft.com/win/2004/08/events/event**">
- <System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" />
<EventID>41</EventID>
<Version>6</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2020-05-27T17:19:38.389705200Z" />
<EventRecordID>3377</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>DESKTOP-UJ8VOCN</Computer>
<Security UserID="S-1-5-18" />
</System>
- <EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">0</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
<Data Name="BugcheckInfoFromEFI">false</Data>
<Data Name="CheckpointStatus">0</Data>
</EventData>
</Event>
error 1:
error 2
- <System>
<Provider Name="Microsoft-Windows-Kernel-EventTracing" Guid="{b675ec37-bdb6-4648-bc92-f3fdc74d3ca2}" />
<EventID>2</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>2</Task>
<Opcode>12</Opcode>
<Keywords>0x8000000000000010</Keywords>
<TimeCreated SystemTime="2020-05-27T17:20:25.977353500Z" />
<EventRecordID>14</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="7268" />
<Channel>Microsoft-Windows-Kernel-EventTracing/Admin</Channel>
</System>
- <EventData>
<Data Name="SessionName">PerfDiag Logger</Data>
<Data Name="FileName" />
<Data Name="ErrorCode">3221225525</Data>
<Data Name="LoggingMode">8388736</Data>
</EventData>
</Event>
error 2:
- <System>
<Level>2</Level>
<Task>2</Task>
<Opcode>12</Opcode>
<TimeCreated SystemTime="2020-05-27T17:07:49.565974400Z" />
<EventRecordID>13</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="6636" />
</System>
- <EventData>
</EventData>
</Event>
error 3:
- <System>
<Provider Name="Microsoft-Windows-WER-SystemErrorReporting" Guid="{ABCE23E7-DE45-4366-8631-84FA6C525952}" EventSourceName="BugCheck" />
<EventID Qualifiers="16384">1001</EventID>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2020-05-27T16:38:22.358431700Z" />
<EventRecordID>3185</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Security />
</System>
- <EventData>
<Data Name="param1">0x0000007e (0xffffffffc0000005, 0xfffff8055a636d16, 0xfffffa06be9d2568, 0xfffffa06be9d1db0)</Data>
<Data Name="param2">C:\Windows\MEMORY.DMP</Data>
<Data Name="param3">339a443c-dfeb-484e-a0d9-a194751a2d01</Data>
</EventData>
</Event>
error 4:
- <System>
<Provider Name="EventLog" />
<EventID Qualifiers="32768">6008</EventID>
<Level>2</Level>
<Task>0</Task>
<TimeCreated SystemTime="2020-05-27T17:19:43.633366100Z" />
<EventRecordID>3367</EventRecordID>
<Security />
</System>
- <EventData>
<Data>18:15:08</Data>
<Data>27/05/2020</Data>
<Data />
<Data />
<Data>7</Data>
<Data />
<Data />
<Binary>E407050003001B0012000F000800F002E407050003001B0011000F000800F0023C0000003C000000000000000000000000000000000000000100000000000000</Binary>
</EventData>
</Event>
my build is:
corsair obsidian 750d airflow edition
corsair H100i pro
I9 9900K
16gb (2x8gb) corsair DDR4 vengeance RGB Pro pc4-28800 3600mhz
550w seasonic focus GX-550 80PLUS gold
gigabyte geforce RTX 2070 Super winderforce OC 8GB GDDR6
Asus Prime Z390-P
500GB PNY XLR8 CS3030 M.2
WD Green 240gb m.2 2280
Windows 10 pro x86
any help please?
2020-06-14T17:08:36+00:00 -
Igor Leyko 112.4K Reputation points Independent Advisor
2020-06-14T17:00:56+00:00 nvlddmkm - NVidia's driver.
