browsing internet and youtube, and pc froze, i had to press start. event viewer shows 15 messages, all Event 14, nvlddmkm. heres the follow messages:
The description for Event ID 14 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\00000089
CMDre 00000000 0000021c 00001000 00000004 00000001
The message resource is present but the message was not found in the message table
\Device\00000089
CMDre 00000000 00000200 00000000 00000005 00000002
\Device\00000089
CMDre 00000000 000020a0 0004020c 00000004 00800000
\Device\00000089
CMDre 00000000 00000200 00042090 00000005 00000002
\Device\00000089
CMDre 00000000 00002628 00040218 00000004 00800000
\Device\00000089
CMDre 00000000 000024a0 00000000 00000004 00000001
\Device\00000089
\Device\00000089
\Device\00000089
\Device\00000089
\Device\00000089
\Device\00000089
CMDre 00000000 00000200 000420a0 00000005 0000000e
\Device\00000089
CMDre 00000000 0000021c 00042228 00000004 00000001
\Device\00000089
\Device\00000089
0cec(3188) 00000000 00000000
