Even brand new hardware may be faulty sometimes. And sometimes PSU may be just overpowered.
Custom built problem
my pc crashed while just watching twitch tv, all the graphics went really low quality then whole pc crashed, had to restart.
i installed geforce experience and as it was doing the update driver, pc crashed and after playing rust, my task bar all went black, i couldnt even see the time.
i have run windows memory test which said no faults, ive done chkdsk and that says no errors.
event viewer shows a critial error, errors and warnings.
critical is:
- <Event xmlns="**http://schemas.microsoft.com/win/2004/08/events/event**">
- <System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" />
<EventID>41</EventID>
<Version>6</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2020-05-27T17:19:38.389705200Z" />
<EventRecordID>3377</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>DESKTOP-UJ8VOCN</Computer>
<Security UserID="S-1-5-18" />
</System>
- <EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">0</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
<Data Name="BugcheckInfoFromEFI">false</Data>
<Data Name="CheckpointStatus">0</Data>
</EventData>
</Event>
error 1:
error 2
- <System>
<Provider Name="Microsoft-Windows-Kernel-EventTracing" Guid="{b675ec37-bdb6-4648-bc92-f3fdc74d3ca2}" />
<EventID>2</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>2</Task>
<Opcode>12</Opcode>
<Keywords>0x8000000000000010</Keywords>
<TimeCreated SystemTime="2020-05-27T17:20:25.977353500Z" />
<EventRecordID>14</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="7268" />
<Channel>Microsoft-Windows-Kernel-EventTracing/Admin</Channel>
</System>
- <EventData>
<Data Name="SessionName">PerfDiag Logger</Data>
<Data Name="FileName" />
<Data Name="ErrorCode">3221225525</Data>
<Data Name="LoggingMode">8388736</Data>
</EventData>
</Event>
error 2:
- <System>
<Level>2</Level>
<Task>2</Task>
<Opcode>12</Opcode>
<TimeCreated SystemTime="2020-05-27T17:07:49.565974400Z" />
<EventRecordID>13</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="6636" />
</System>
- <EventData>
</EventData>
</Event>
error 3:
- <System>
<Provider Name="Microsoft-Windows-WER-SystemErrorReporting" Guid="{ABCE23E7-DE45-4366-8631-84FA6C525952}" EventSourceName="BugCheck" />
<EventID Qualifiers="16384">1001</EventID>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2020-05-27T16:38:22.358431700Z" />
<EventRecordID>3185</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Security />
</System>
- <EventData>
<Data Name="param1">0x0000007e (0xffffffffc0000005, 0xfffff8055a636d16, 0xfffffa06be9d2568, 0xfffffa06be9d1db0)</Data>
<Data Name="param2">C:\Windows\MEMORY.DMP</Data>
<Data Name="param3">339a443c-dfeb-484e-a0d9-a194751a2d01</Data>
</EventData>
</Event>
error 4:
- <System>
<Provider Name="EventLog" />
<EventID Qualifiers="32768">6008</EventID>
<Level>2</Level>
<Task>0</Task>
<TimeCreated SystemTime="2020-05-27T17:19:43.633366100Z" />
<EventRecordID>3367</EventRecordID>
<Security />
</System>
- <EventData>
<Data>18:15:08</Data>
<Data>27/05/2020</Data>
<Data />
<Data />
<Data>7</Data>
<Data />
<Data />
<Binary>E407050003001B0012000F000800F002E407050003001B0011000F000800F0023C0000003C000000000000000000000000000000000000000100000000000000</Binary>
</EventData>
</Event>
my build is:
corsair obsidian 750d airflow edition
corsair H100i pro
I9 9900K
16gb (2x8gb) corsair DDR4 vengeance RGB Pro pc4-28800 3600mhz
550w seasonic focus GX-550 80PLUS gold
gigabyte geforce RTX 2070 Super winderforce OC 8GB GDDR6
Asus Prime Z390-P
500GB PNY XLR8 CS3030 M.2
WD Green 240gb m.2 2280
Windows 10 pro x86
any help please?
2020-06-13T18:33:12+00:00 i have not got another power supply, its brand new though, if that makes a difference?
Igor Leyko 112.4K Reputation points Independent Advisor
2020-06-13T18:22:32+00:00 Can you replace power supply unit for test?
2020-06-05T20:11:46+00:00 DistributedCOM 10010 error does not have negative influence to PC's stability.
See some recommendations at https://social.technet.microsoft.com/Forums/windowsserver/en-US/f7211cff-9221-4cc5-aea8-16bd7797a93c/event-id-10010-dcom-error?forum=winservermanager
2020-06-05T12:44:37+00:00 the link takes you to a page which is unavailable.
no errors since, apart from last night when i shut down pc, i thought it was all fine, but when i checked event log today, it give me the same error 32 times
Event 10010, distributedCOM
The server {AB8902B4-09CA-4BB6-B78D-A8F59079A8D5} did not register with DCOM within the required timeout.
- <System>
<Provider Name="Microsoft-Windows-DistributedCOM" Guid="{1B562E86-B7AA-4131-BADC-B6F3A001407E}" EventSourceName="DCOM" />
<EventID Qualifiers="0">10010</EventID>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8080000000000000</Keywords>
<TimeCreated SystemTime="2020-06-05T01:03:57.7866466Z" />
<EventRecordID>5312</EventRecordID>
<Correlation ActivityID="{5d455add-e73b-452d-ae93-934957c9b46c}" />
<Execution ProcessID="1168" ThreadID="2160" />
<Computer>DESKTOP-KA4BF7B</Computer>
<Security UserID="S-1-5-21-1277689241-1081358554-2017141622-1001" />
</System>
- <EventData>
<Data Name="param1">{AB8902B4-09CA-4BB6-B78D-A8F59079A8D5}</Data>
</EventData>
</Event>
