Please check the link in description. But this error is not critical and should not influence your PCusage.
Custom built problem
my pc crashed while just watching twitch tv, all the graphics went really low quality then whole pc crashed, had to restart.
i installed geforce experience and as it was doing the update driver, pc crashed and after playing rust, my task bar all went black, i couldnt even see the time.
i have run windows memory test which said no faults, ive done chkdsk and that says no errors.
event viewer shows a critial error, errors and warnings.
critical is:
- <Event xmlns="**http://schemas.microsoft.com/win/2004/08/events/event**">
- <System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" />
<EventID>41</EventID>
<Version>6</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2020-05-27T17:19:38.389705200Z" />
<EventRecordID>3377</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>DESKTOP-UJ8VOCN</Computer>
<Security UserID="S-1-5-18" />
</System>
- <EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">0</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
<Data Name="BugcheckInfoFromEFI">false</Data>
<Data Name="CheckpointStatus">0</Data>
</EventData>
</Event>
error 1:
error 2
- <System>
<Provider Name="Microsoft-Windows-Kernel-EventTracing" Guid="{b675ec37-bdb6-4648-bc92-f3fdc74d3ca2}" />
<EventID>2</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>2</Task>
<Opcode>12</Opcode>
<Keywords>0x8000000000000010</Keywords>
<TimeCreated SystemTime="2020-05-27T17:20:25.977353500Z" />
<EventRecordID>14</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="7268" />
<Channel>Microsoft-Windows-Kernel-EventTracing/Admin</Channel>
</System>
- <EventData>
<Data Name="SessionName">PerfDiag Logger</Data>
<Data Name="FileName" />
<Data Name="ErrorCode">3221225525</Data>
<Data Name="LoggingMode">8388736</Data>
</EventData>
</Event>
error 2:
- <System>
<Level>2</Level>
<Task>2</Task>
<Opcode>12</Opcode>
<TimeCreated SystemTime="2020-05-27T17:07:49.565974400Z" />
<EventRecordID>13</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="6636" />
</System>
- <EventData>
</EventData>
</Event>
error 3:
- <System>
<Provider Name="Microsoft-Windows-WER-SystemErrorReporting" Guid="{ABCE23E7-DE45-4366-8631-84FA6C525952}" EventSourceName="BugCheck" />
<EventID Qualifiers="16384">1001</EventID>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2020-05-27T16:38:22.358431700Z" />
<EventRecordID>3185</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Security />
</System>
- <EventData>
<Data Name="param1">0x0000007e (0xffffffffc0000005, 0xfffff8055a636d16, 0xfffffa06be9d2568, 0xfffffa06be9d1db0)</Data>
<Data Name="param2">C:\Windows\MEMORY.DMP</Data>
<Data Name="param3">339a443c-dfeb-484e-a0d9-a194751a2d01</Data>
</EventData>
</Event>
error 4:
- <System>
<Provider Name="EventLog" />
<EventID Qualifiers="32768">6008</EventID>
<Level>2</Level>
<Task>0</Task>
<TimeCreated SystemTime="2020-05-27T17:19:43.633366100Z" />
<EventRecordID>3367</EventRecordID>
<Security />
</System>
- <EventData>
<Data>18:15:08</Data>
<Data>27/05/2020</Data>
<Data />
<Data />
<Data>7</Data>
<Data />
<Data />
<Binary>E407050003001B0012000F000800F002E407050003001B0011000F000800F0023C0000003C000000000000000000000000000000000000000100000000000000</Binary>
</EventData>
</Event>
my build is:
corsair obsidian 750d airflow edition
corsair H100i pro
I9 9900K
16gb (2x8gb) corsair DDR4 vengeance RGB Pro pc4-28800 3600mhz
550w seasonic focus GX-550 80PLUS gold
gigabyte geforce RTX 2070 Super winderforce OC 8GB GDDR6
Asus Prime Z390-P
500GB PNY XLR8 CS3030 M.2
WD Green 240gb m.2 2280
Windows 10 pro x86
any help please?
2020-06-02T22:57:33+00:00 doesnt tell me any session name, this is the xml view:
- <System>
<Level>2</Level>
<Task>2</Task>
<Opcode>12</Opcode>
<TimeCreated SystemTime="2020-06-02T20:28:03.5502884Z" />
<EventRecordID>9</EventRecordID>
<Correlation />
<Execution ProcessID="8708" ThreadID="9864" />
<Computer>DESKTOP-KA4BF7B</Computer>
<Security UserID="S-1-5-21-1277689241-1081358554-2017141622-1001" />
</System>
- <EventData>
<Data Name="SessionName">dfa2c640-651d-488d-a479-2fd7a7ca6e29</Data>
<Data Name="ErrorCode">3221225506</Data>
<Data Name="LoggingMode">4194560</Data>
</EventData>
</Event>
Igor Leyko 112.4K Reputation points Independent Advisor
2020-06-02T22:50:19+00:00 Solution depends of session name. Please look for details of event and check if there are some links to help.
2020-06-02T22:36:28+00:00 ahh ok, no critical errors upto now, i have 1 new error:
event id 2, Kernel-EventTracing
Session "dfa2c640-651d-488d-a479-2fd7a7ca6e29" failed to start with the following error: 0xC0000022
2020-06-02T18:15:53+00:00 These errors do not mean something serious. Treat them as information.
