Custom built problem
2020-05-27T18:14:43+00:00
my pc crashed while just watching twitch tv, all the graphics went really low quality then whole pc crashed, had to restart.
i installed geforce experience and as it was doing the update driver, pc crashed and after playing rust, my task bar all went black, i couldnt even see the time.
i have run windows memory test which said no faults, ive done chkdsk and that says no errors.
event viewer shows a critial error, errors and warnings.
critical is:
- <Event xmlns="**http://schemas.microsoft.com/win/2004/08/events/event**">
- <System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" />
<EventID>41</EventID>
<Version>6</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2020-05-27T17:19:38.389705200Z" />
<EventRecordID>3377</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>DESKTOP-UJ8VOCN</Computer>
<Security UserID="S-1-5-18" />
</System>
- <EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">0</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
<Data Name="BugcheckInfoFromEFI">false</Data>
<Data Name="CheckpointStatus">0</Data>
</EventData>
</Event>
error 1:
error 2
- <System>
<Provider Name="Microsoft-Windows-Kernel-EventTracing" Guid="{b675ec37-bdb6-4648-bc92-f3fdc74d3ca2}" />
<EventID>2</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>2</Task>
<Opcode>12</Opcode>
<Keywords>0x8000000000000010</Keywords>
<TimeCreated SystemTime="2020-05-27T17:20:25.977353500Z" />
<EventRecordID>14</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="7268" />
<Channel>Microsoft-Windows-Kernel-EventTracing/Admin</Channel>
</System>
- <EventData>
<Data Name="SessionName">PerfDiag Logger</Data>
<Data Name="FileName" />
<Data Name="ErrorCode">3221225525</Data>
<Data Name="LoggingMode">8388736</Data>
</EventData>
</Event>
error 2:
- <System>
<Level>2</Level>
<Task>2</Task>
<Opcode>12</Opcode>
<TimeCreated SystemTime="2020-05-27T17:07:49.565974400Z" />
<EventRecordID>13</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="6636" />
</System>
- <EventData>
</EventData>
</Event>
error 3:
- <System>
<Provider Name="Microsoft-Windows-WER-SystemErrorReporting" Guid="{ABCE23E7-DE45-4366-8631-84FA6C525952}" EventSourceName="BugCheck" />
<EventID Qualifiers="16384">1001</EventID>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2020-05-27T16:38:22.358431700Z" />
<EventRecordID>3185</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Security />
</System>
- <EventData>
<Data Name="param1">0x0000007e (0xffffffffc0000005, 0xfffff8055a636d16, 0xfffffa06be9d2568, 0xfffffa06be9d1db0)</Data>
<Data Name="param2">C:\Windows\MEMORY.DMP</Data>
<Data Name="param3">339a443c-dfeb-484e-a0d9-a194751a2d01</Data>
</EventData>
</Event>
error 4:
- <System>
<Provider Name="EventLog" />
<EventID Qualifiers="32768">6008</EventID>
<Level>2</Level>
<Task>0</Task>
<TimeCreated SystemTime="2020-05-27T17:19:43.633366100Z" />
<EventRecordID>3367</EventRecordID>
<Security />
</System>
- <EventData>
<Data>18:15:08</Data>
<Data>‎27/‎05/‎2020</Data>
<Data />
<Data />
<Data>7</Data>
<Data />
<Data />
<Binary>E407050003001B0012000F000800F002E407050003001B0011000F000800F0023C0000003C000000000000000000000000000000000000000100000000000000</Binary>
</EventData>
</Event>
my build is:
corsair obsidian 750d airflow edition
corsair H100i pro
I9 9900K
16gb (2x8gb) corsair DDR4 vengeance RGB Pro pc4-28800 3600mhz
550w seasonic focus GX-550 80PLUS gold
gigabyte geforce RTX 2070 Super winderforce OC 8GB GDDR6
Asus Prime Z390-P
500GB PNY XLR8 CS3030 M.2
WD Green 240gb m.2 2280
Windows 10 pro x86
any help please?
    2020-06-02T10:55:46+00:00
    no critical errors or errors all day, i done a number of shut downs to test this, but when i was going to bed and shut down, all seemed fine, checked event viewer today and got 40 errors.
    error 1: event id 10010 DistributedCOM  (this happened first)
    The server microsoft.windowscommunicationsapps_16005.12827.20200.0_x64__8wekyb3d8bbwe!microsoft.windowslive.calendar.AppXwkn9j84yh1kvnt49k5r8h6y1ecsv09hs.mca did not register with DCOM within the required timeout.
    error 2: event id 10010 DistributedCOM  (this happened 37 times all at the same time. milliseconds arpart)
    The server {AB8902B4-09CA-4BB6-B78D-A8F59079A8D5} did not register with DCOM within the required timeout.
    error 3: event id 7009 Service Control Manager
    A timeout was reached (30000 milliseconds) while waiting for the Steam Client Service service to connect.
    error 4: event id 7000 Service Control Manager
    The Steam Client Service service failed to start due to the following error:
    The service did not respond to the start or control request in a timely fashion.
  2. Igor Leyko 112.4K Reputation points Independent Advisor
    2020-06-01T22:16:51+00:00
    Keep us informed please.
    2020-06-01T21:20:07+00:00
    still no errors upto now. been gaming abit too. fingers crossed it stays ok :)
  4. Igor Leyko 112.4K Reputation points Independent Advisor
    2020-06-01T18:51:45+00:00
    If you shuts down PC normally but get 41 (63) and 6008 errors this is BIOS problem.
    2020-06-01T16:39:12+00:00
    no i shut it down properly. windows > power > shut down. each shut down i do, causes 2 errors and 1 critical in event viewer all related to shutting down unexpected.
    i have reset event viewer, turned off fast startup in windows and upto now (3 hours) no errors as of yet.
