Other issues or features related to Microsoft Edge on Windows 10
* Related thread (locked)
Microsoft Edge Quick Links Keep Disappearing
My quick links just won't stop clearing themselves. I have tried turning on and off quick links and turning on and off custom mode, repaired and reset Edge, and cleared browser data. It still won't stop, and I haven't received any reply from my last report, so I am asking for more assistance. I am actually wondering if this is a new bug that will have to be fixed in the next browser update.
Just found out the the app somehow wasn't installed through any of those means, even not through the store, so I had to install feedback hub from there. I got it working now. What do I do on feedback hub again?
Hi 40U538072, I am Paulo and I'd like to help.
Are you allowing cookies on the New Tab Page, or are you perhaps clearing cookies on browser exit? The data on your new tab page is default to ntp.msn.com so if cookies are being cleared, anything you pinned on your quick links will be removed.
Sorry, but I don't think none of that helped. I guess I will try to submit a bug report. What do you mean by detailed results I post back? What detailed post? I'm lost.
Hello, I'm Greg, here to help you with this.
Here are fixes for Edge Quick Links disappearing:
https://windowsreport.com/microsoft-edge-quick-...
(Avoid ad links which intrude into editorial copy, especially DO NOT INSTALL Restoro, PC Repair Tool and Reimage ads)
If none of those work then here are all other possible fixes for Edge:
https://answers.microsoft.com/en-us/microsofted...
If nothing works then if you want to report this as a bug to Edge Developers in the Edge Hub (three dots to right of URL address bar) then Help & Feedback, then Feedback form to fill out. They may not even see it here.
Feel free to ask back any questions. Based on the detailed results you post back, I will have other suggestions if necessary.
______________________________________________
I do not clear or block cookies on the new tab page. I do not clear cookies on exit.
