Greetings Mark,
The best option available, is while the Surface is connected to a second monitor, to set it to "Second screen only".
You can do this by:
- Swipe from the right
- Touch Devices
- Touch Second Screen
- Touch Second Screen only.
I've read many question posted similar to this. The truth is none of them answer it. Let's change that or at least get Microsoft to do something about it. Every other computer in the world can do this...why not the surface pro!!! I see the exact behavior occur that I desire when I go to second screen only option...but it doesn't stay there. For obvious reasons....we need a new power option! Does anybody know how to effectively "yell" at Microsoft?
***Subject edited for clarity by the moderator.***
Greetings Mark,
You can do this by:
Figured it out - held power button for several seconds..
I did this accidentally, with no second screen attached, and now cannot figure out how to get the screen back on the touchpad! it's black, power is on. pls help?
Three cheers and hats off to you, Steven B. Thanks for your solution!
To make this even easier to do, why not extend the "Screen" control in PC Settings to go so dim that it is effectively off? You would have to then still create way to turn it back on with a touch.
