How to turn off Surface Pro monitor only WITHOUT it sleeping?
2013-06-25T07:44:51+00:00
I've read many question posted similar to this.  The truth is none of them answer it. Let's change that or at least get Microsoft to do something about it. Every other computer in the world can do this...why not the surface pro!!! I see the exact behavior occur that I desire when I go to second screen only option...but it doesn't stay there.  For obvious reasons....we need a new power option! Does anybody know how to effectively "yell" at Microsoft?
***Subject edited for clarity by the moderator.***
2013-09-19T00:48:23+00:00
Greetings Mark,
The best option available, is while the Surface is connected to a second monitor, to set it to "Second screen only".
You can do this by:
  1. Swipe from the right
  2. Touch Devices
  3. Touch Second Screen
  4. Touch Second Screen only.
52 additional answers
    2014-08-01T17:48:34+00:00
    Julien is right, Surface Pro 3 is capable of turning the screen off after a period of inactivity without going to sleep.  Navigate to:
    Control Panel / Hardware and Sound / Power Options
    Click on "Change Plan Settings," then click on "Change advance power settings."
    A new window called "Power Options" will open.  Expand the list item "Display" then expand the sub-item "Turn off display after".
    At this point, it should be obvious which settings to adjust to turn the display off when you want and save battery power.
    Thanks, Julien!
    2014-07-31T14:55:48+00:00
    I'm using Surface Pro 3 with a Toshiba dynadock so i can run 2 external monitors.
    I can go into the Power Options on the surface pro and set "Put the computer to sleep" to NEVER when plugged in.
    I can then go to the advanced settings and under "Display" i can set the "Turn off display after" setting for plugged in to 30 minutes.  Doing this changes the "Put the computer to sleep" setting back to 30 minutes!
    I know it is related to this issue of not being able to turn of the SP screen without putting SP to sleep.  Just wanted to point this out.
    relayman
    2014-01-07T17:34:58+00:00
    Open Windows mobility centre,
    Enable presentation mode,
    Switch off the screen with the button.
    With presentation mode on, the device doesn't actually sleep and will carry on working on the background.
    I've used this on my rt devices, never tried it on a pro.
    2013-11-10T22:10:56+00:00
    If you have accidentally locked up the Surface Pro for any reason, you can do a hardware shutdown by simply holding down the power button for a full five seconds.
    This is not written anywhere, but it works.  If you'd like to test it yourselves, leave an unsaved notepad window on your screen and try:
    1)  Power off by tapping the power button.  This puts you into light sleep or standby mode.  Your notepad app will be running when you power back on and log in.  This is not a shutdown.
    2)  Power off by holding the power button down two seconds.  This is still not a shutdown event, as your notepad window will be there when you press the power button to start up.
    3)  With your notepad app running, hold down the power button for a full five seconds.  When you tap the button to start up, you will see the Operating System startup notice and it will take noticeably longer.  You will log on and see your desktop or whatever applications are set to start automatically, and your notepad window will be gone to oblivion.
    This SHOULD recover you, JRC369, from your lockup caused by switching to a phantom second screen.  If it does not, reply back and we'll take this to the next level.
    Cheers,
    Mark
