Surface Pro 3 does not connect to recent Samsung Series 7 TV
2014-09-21T16:09:32+00:00
my Surface Pro 1 does connect well with my Samsung Smart TV series 7. However, my new Samsung Pro 3 wont connect. It finds the TV and then tries to establish connection and asks to wait - maybe the TV should not popup a PIN code - but that never happens and the connection times out. Interestingly the Surface Pro 3 gets listed in the Samsung network device settings and is set to "allowed" for connection but the Surface Pro 3 still wont connect. Note i have deployed all latest updates on Samsung TV as well as Surface Pro 3.
I would appreciate to get this working again.
Thx,
Bernd
    2015-08-20T09:39:37+00:00
    Tried the same on my UE40H6400. No such luck, unfortunately.
    2015-08-18T21:58:56+00:00
    Follow-up to previous message: i could my windows 10 surpro 3 also connect now with my 75 inch Samsung UE75F8090. this samsung is an UHD TV and the surpro now automatically sets screen resolution to 1920x1080 and thus it works at proper speed and the handshake works too. btw to make it work after windows 10 upgrade i had to delete the TV as known device and re-add it.
    so i am happy to have finally a solution.
    -bernd
    2015-08-18T10:55:18+00:00
    That's really great news.
    2015-08-17T22:49:31+00:00
    after long wait it works for me at least on my 55 inch samsung TV. need to test with my 75 inch too. will provide an update.
    so i upgraded my surface pro 3 now to windows 10 and suddenly it connects fine with my samsung UE55HU7580. so good news so far.
    -bernd
    2015-08-06T13:27:34+00:00
    Still no luck for me either.
    Have two 50' Samsung's - one is on 1122, and the other manually downloaded and installed 1124.  No difference.
    So frustrating...
    Steve
