Surface Pro 3 does not connect to recent Samsung Series 7 TV
2014-09-21T16:09:32+00:00
my Surface Pro 1 does connect well with my Samsung Smart TV series 7. However, my new Samsung Pro 3 wont connect. It finds the TV and then tries to establish connection and asks to wait - maybe the TV should not popup a PIN code - but that never happens and the connection times out. Interestingly the Surface Pro 3 gets listed in the Samsung network device settings and is set to "allowed" for connection but the Surface Pro 3 still wont connect. Note i have deployed all latest updates on Samsung TV as well as Surface Pro 3.
I would appreciate to get this working again.
Thx,
Bernd
    2017-02-04T03:31:21+00:00
    Hey,
    got some tips from a german surface mvp.
    Latest update from 31.01.2017 improves some mircast things.
    January 30 release
    The following updates are available for Windows 10 Surface Pro 3 devices:
    Intel Corporation – Display – 20.19.15.4568 Intel(R) HD Graphics Family <br><br><ul><br><li>20.19.15.4568 improves Miracast and docked video performance.</li></ul><br><br>Intel(R) Display Audio<br><br><ul><br><li>6.16.00.3197 improves Miracast and docked video performance.</li></ul>
    Microsoft - System Firmware update Surface Pro UEFI<br><br><ul><br><li>3.11.2050.0 improves system performance for the latest Windows versions.</li></ul>
    Maybe give it another try?
    Regards
    flode
    2016-02-20T19:30:00+00:00
    Not working on my UN65HU8550 with my Surface Pro 3.  They try to connect but it fails after the TV shows "Loading" for a moment...
    Please help!
